Bosch Classixx 1200 Express - metal got under the drum
A metal bra bone has got under the drum and is making a screeching noise , can I get at the drum from the back of the m/c or do I need a technician to sort it out, I have opened the pump drain and found only fluff in there ?? Bosch Classixx 1200 Express
  • Washing Mach... Master
  • 744 Answers
This video will show you how to get into the drum through the heating element and remove the bra wire on this Bosch front loader washing machine
we have all bosch repairs in our channel
Posted on Jul 23, 2013
    Sergeant:
    Champion:
  • 333 Answers
If the obstruction is between the drum inner and outer then you may have to remove the rubber door seal to gain access. ISOLATE THE POWER FIRST. The problem with disturbing seals is that they may no longer seal when replaced! - Particularly if the machine is a few years old.
Probably best to leave it to a guy with a van full of spares.
Posted on Apr 01, 2008
F21 flashing on my bosch classixx 6 1200 express
F21 is a motor fault and in some cases can also involve a module fault. It could be as simple as the brushes need replacing or the drum has been severely out of balance.
Mar 21, 2013 | Bosch Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Ssomething scraping on drum at the back on Classixx 1200 express?.
Possibly a stray bra wire, trapped around the heater element, try turning the drum slowly and if you're lucky the end will pop up through one of the drum holes, use a pair of decent pliers to pull it free. The worse case scenario if is not a foreign object is faulty bearings.
Nov 26, 2011 | Bosch Washing Machines
I have a bosch classixx express 1200 washer and when its on rinse it makes such a loud noise and also when its on spin, its like a grinding noise. hope u can help.
The noise is relative to the motion and so the areas to check must be the moving parts of the washer. So shut down unit , disconnect power and check manually the movement of the motor, the rotor and the drum.
the bush can be worn out the suspension can be weak or the belt can be faulty.
your observation while the motor works is important.
Check these links below for some help :\
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Feb 15, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Makes a fairly loud noise similar to metal in drum .occurs intermittently. Appears to be related to draining.
Coin, bra-underwire, etc. Could be between rotating and fixed drum. Or may have flushed through to the filter and fouling the pump. Try the filter (remove, clean, check 'up pipe') first.
Good luck.
Jul 07, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Washing Machines Logo
569 people viewed this question
Top Washing Machines Experts
