Washer how do u work the whirlpool awm321 washer as just brought it and got no instructions
  • 5,911 Answers
Go to managemyhome.com. This is a free home topic web site. I have managed to download user manuals there before. You will need to register and create a user name and password. Under the HOME heading, click on the "Products and Manuals" link. Type in your information in the drop down menus and you might find your owner's manual for your washer there. Double check your model number, I don't believe the one you posted is correct. It will be located around the door or lid opening. I hope this helps you.
Posted on Apr 01, 2008
Where can I download a manual for Whirlpool AWM321
You could go to whirlpool.com and click ower center and download a maual for your washer,i tried that but it says the model number couldn't be matched
The following is from the whirlpool website and it shows where to find the model#
Please find the type of appliance you are interested in and click on the link to view the likely location of the model number plate on that appliance here is where the model# could be found
Type of Appliance Model Number Plate Location Range Inside oven drawer, on oven rim Wall Oven Inside oven drawer, on rim Cooktop On underside of unit Microwave Inside microwave, on rim Dishwasher Inside dishwasher, on rim Refrigerator Inside refrigerator, on wall Trash Compactor Inside, on rim Food Waste Disposer Attached to the unit Washer Beneath washer lid, on tub rim Dryer Inside dryer door, on rim.
Jul 29, 2011 | Washing Machines
Error F05 on my awod as147 steam washing maching
F05 for Whirlpool washers decodes as 'NTC failure'. NTC stands for Negative Temperature Co-efficient and all that means is the water temperature sensor ;-0)
I have heard that occasionally it can be brought back to life by pouring in a few kettles of hot water into the washer, leaving for 10 minutes, spinning the water out and re-trying. If it doesn't work it means a service call. Sorry ;-0(
Good luck,
John C.
Mar 20, 2011 | Whirlpool Washing Machines
Was so proud when my husband brought home te
I wouldn't blame it on the washer but did you have the same problem with your previous washer? Are you using the same water source as previously. Do you use a chlorine bleach with it and did you use it before? Is the cheer a liquid or powder. You should us a powder.
Mar 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer. It worked fine
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Dec 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have A Whirlpool awm321 washing machine it'sa farly all macheine, the other day i did a load of washing and it was fine i came backafta an hour to do sum more and for sum reason it dosent seem to run...
U need to take the pump off and clean it as well as empty the filter which will be full of ****/socks/tights etc.This is a common problem on mine.Pump not easy to reach you will have to tilt the machine backwards to reach underneath and do the removal.You will soon get accustomed to this lol
Jul 29, 2008 | Washing Machines
Whirlpool washer
try getting a bottom load washer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
