Question about Dell Inspiron 8500 Notebook
Laptop display goes black and then rebuilds each window
While using the laptop, sometimes the display goes black, starts to rebuild the windows, flashes to black, and then rebuilds each window until it is back to normal.
Sometimes this only occurs once, others it will happen 5 times or more in succession.
This is Windows XP Pro
Drivers are up to date.
Thanks
  • 4 Answers
This is problem with operating system or with the RAM,Try re-installing Operating system..If still Happens Change the RAM
Posted on Apr 01, 2008
SOURCE:
How do I format my Toshiba Satellite A505 laptop since it came with no disks?
Bea,
Not sure what you intend to do by saying you want to format the laptop. If you mean that you want to restore the laptop to 'out of box' condition, or as new, then you must look for one of two things:
- If, while in Windows, you click Start, then All Programs, and locate a listing for Toshiba, then look inside that category for an application to rebuild, or otherwise restore the laptop to the as new condition.
... or ...
- When you first power on the laptop, usually you see on the first screen an option for SETUP, like Hit F2 for Setup, or Hit F10 for BIOS, etc. There may be one specifically for getting into the Toshiba Rebuild routine.
Most recent laptops have a hidden partition, which contains all the files that are used to produce a brand new condition for your laptop.
Sometimes there are two options, one to wipe everything and rebuild, and one to actually protect your documents, but not any added later applications, while it rebuilds it.
Those are the things to look for. Be careful and be certain what it is you wish to do to it, before you do it. Most of those options, when you find them, are not reversible.
If there is something that you did recently that you want to undo, you might be able to accomplish that if your laptop is set to retain System Restore information every few days, or before major upgrades, and you can restore to the day before whatever it is you might have done that is making it run strangely now.
Cheers!
-a.
Jun 24, 2012 | Toshiba Satellite A505 Notebook
Second monitor is connected but screen remains
Hi, Ronald.
If you look at the function keys (F1 through F12) on the top row of your keyboard, you should see a CRT/LCD label or symbol, typically on F4 or F8 (may be different for your laptop).
Press the Fn key (typically on the left bottom of your keyboard) with that function key and you would toggle through accessing your laptop display, your external monitor display and both displays (may not be in that order).
Hope this helps.
Sep 17, 2009 | Microsoft Windows Vista Home Premium with...
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
I have an acer 5570z lap top. it will not start. i get an error that says Windows failed to start. it says to insert windows installation disc and restart. i bought it used but received 2 homemade discs...
If this Acer laptop has the 'hidden' system rebuild disk, you might want to try using it to rebuild the system. Many of them have a hidden partition on which the whole system resides, to allow you to wipe out and rebuild the computer.
Check at the Acer web site to see if your model has this.
My Acer 5920 laptop - which I am using to answer this, has this very feature and I have used it twice when I peronally screwed up my installation of Vista, by doing things I should not have done <g>. Turned out just fine.
You might get there using F2 upon powering it on.
Jun 19, 2009 | Computers & Internet
My laptop suddenly will not display anything upon power up
have you tried going back to restore point..some times windows create restore point when changing configuration on computer.
click start>>>all programs>>>accessories>>>system tools>>>system restore>>>restore my computer
Mar 16, 2009 | HP Compaq Presario C500t Notebook
Small Screen Size after rebuild
had same problem sometimes you can adfust pixels to 800X600 or larder to repair but as in my case i had to flash the biois to repair it.
Dec 05, 2008 | HP Compaq nx9010
My screen wont display icons
insert your WIN OS installation CD - But select recovery.
Attempt to rebuild windows...
This sounds like hard drive issue - sometimes a rebuild will temporarily get around this - but I would strongly recommend once running to do a surface / scan disk...
Aug 15, 2008 | Toshiba Satellite 5005-S504 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
42 people viewed this question
Ekse
Clive
Clive
Alun Cox
