Question about Kirby Ultimate G Bagged Upright Vacuum
Electrical My Kirby Ultimate G won't turn on when it is supposed to, sometimes it will and sometimes it won't ...also I see greenish blue sparks in the machine where the handle attaches to the motor when it is on. As a side note, the shampoo attachment won't make suds anymore.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Posted on Apr 08, 2008
SOURCE:
Kirby sparks and smells
it probably needs new carbon brushes in the motor,DO NOT run anymore for fear of burning motor out.
Jan 16, 2013 | Kirby Ultimate G Bagged Upright Vacuum
I am trying to replace the brushbelt. I have the brush off not surewhich end goes where. also I had it on once but the belt was off when it was supposed to on. I cant find my instructions ! help
I am going Kirby "G" crazy. I hope this URL will be of help to you:
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
If it is of help, please rate me for this. Thank you.
Sep 24, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Cost of Repairing my Kirby G5
I believe if you take it to a kriby dealer it should be free the motor has a lifetime warrenty
Jun 28, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Where can i download a manual for ultimate g kirby vac
Check out our video manual on the home page GoodVac.com
Or
For more in-depth manual go HERE.
Good Luck,
Rocky
Dec 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G
Hi There, Could be a number of differant things really. Just check that the both the safety switches are being activated but other than that it will need to go to a repair center. Many Thanks Chris www.elidistribution.co.uk
Aug 14, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
258 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
