My phillips tv model#27pt5445/37 serial#ya1a0540045497.my question is will i need a converter box for this i have a roof aerial.i donot have cable.
I have this same t.v. According to the product brochure it has NTSC connections, not ATSC. According to the government's DTV website, t.v.s that don't have ATSC connections need a converter box.
So, yes, your t.v., and mine, need digital t.v. converter boxes.
Posted on Feb 21, 2009
  • 149 Answers
Yes you do if you dont have digital tunner
Posted on Apr 01, 2008
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
I just bought a converter box for a Mitsubishi screen tv cause I don't have cable but I'm not getting picture or audio n the converter says boot what does that mean
manufacturer & model number of converter box? do you have an outdoor (aerial) or indoor antenna connected to the converter box?
Oct 04, 2015 | Mitsubishi Televison & Video
I do not have a external aerial so can I get digital tv without a roof mounted aerial?
Doesn't matter how you pick up the digital signal, it's can the TV tune them in, and can you see them.
If not you'll need a converter box.
Jan 15, 2010 | Televison & Video
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
Since digital switchover yesturday loss of digital channels
It may well be your aerial despite the success with your DVD recorder.
Digital signals are very much weaker than analogue ones, and when multiple devices share a single aerial you can get this kind of problem. You also lose about 60% of the signal at each point in your aerial cable where there are signal splitters.
There are a number of possible solutions:-
First, look at every bit of coaxial cable you have between the aerial and each appliance. Check especially at the aerial end for corrosion or poor shielding/installation and especially for evidence of rain water penetration. If the aerial is on the roof then it will cost almost as much to get the aerial inspected as it will to have it replaced, so skip to the next option. But otherwise, check along every bit of the cable for any cuts or splits in the insulation and properly remake every junction or joint if there are any doubts about them. If the cable is in poor condition then consider option three instead.
The second is to try to see if you get a better digital signal from another transmitter, this will involve trying different aerial positions so is impractical if your aerial is roof mounted but is worth trying if it's in the loft instead. It doesn't always follow that your best digital signal will be from the transmitter which you used for analogue transmissions.
Thirdly, if you're still using the same aerial as you have done for years then it's worth upgrading to one optimised for digital reception. When doing this it's foolish not to replace the cabling as well as you need it to be as good as possible. With analogue, many installers got away with using cheaper cable intended only for very short cable runs from the wall socket to the tv.
The fourth option is the budget option but can work as well as the third option: fit an additional analogue style aerials and run a separate cable down to each appliance. If these are fitted in the loft and you have the space, then there's no aesthetic or planning concerns. Normally the extra cables can run partway down through the house alongside existing cables, but for best signal quality keep them separate and ensure that the cable runs as as short as possible.
One further thing which you may want to try before all else: connect your digital box directly to the aerial cable which currently feeds your dvd recorder. Leave all other tv devices disconnected from the aerial. If the box retunes correctly then it's definitely a supply of signal issue as outlined above and if not then you should add the exact make and model of your digibox as a comment to this answer as there are a large number of earlier digibox models which cannot retune correctly due to evolving standards.
Jul 02, 2009 | Sanyo Televison & Video
Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
May 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
DIGITAL READY?
found phone number and called phillips. it is ready. any Phillips tv from 05 on is ready. Thanks
Nov 17, 2008 | Televison & Video
Is my tv digital compatible or not
I have a Sylvania 27 inch tv from 1986. I currently have Cable TV. Is it possible that it will not work even with a converter box?
Apr 15, 2008 | RCA P46920BL 46" Rear Projection...
Pay tv cable
you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Mar 06, 2008 | Televison & Video
Coaxle cable (from aerial on roof to TV or top box)
I believe that you use the same type of connector as in the UK.
If so, this site or this video should help you.
Even if your connector is a slightly different design, the principles are the same.
Hope this helps,
Matt
Mar 05, 2008 | Audio Players & Recorders
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
