Question about Panasonic Lumix DMC-TZ1 Digital Camera
Camara lock my camara says "memory card protected"; how can i unlock it??
  • 477 Answers
Take out the memory card there is a little lock on the side of it. move the lock over and this should fix your issue. hope this helps
Posted on Apr 01, 2008
Why does my camara tell me that my memory card is write protected
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
Jul 05, 2016 | Nikon COOLPIX L20 Digital Camera
How to unlock "card lock" on a Exilim EX-V7 camara
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 07, 2013 | Casio Exilim EX-S500 Digital Camera
Camera
Do you mean the memory card? SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 01, 2013 | GE X500 Digital Camera
Remove write protect from camara
Apr 02, 2013 | Olympus TOUGH TG-310 Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
When i turn on my camara it says card lock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 19, 2012 | Canon PowerShot SD880 IS Digital Camera
Write protect problem in a A1235 camara
Aug 21, 2011 | General Electric A735 Digital Camera
Why my camara reads card protected.,,,i pearches a memory card and the camara doent work
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Nov 26, 2010 | Polaroid a550 Digital Camera
Protec. Escr. ¿qué significa esto?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 28, 2010 | Olympus FE-240 Digital Camera
The camara said camara memory locked i need to know how i can unlocked
Did you using SD card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
Jul 09, 2009 | Canon PowerShot A460 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
111 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
