HOOK UP TRYING TO HOOK UP MY: OLD TV- ONLY ANT INPUT ( BUT I HAVE AN AMPLIFIED RF MODULATOR THAT HAS ANT IN/OUT AN RCA JACKS). RECOTON F.R.E.D. STEREO DECODER CD/DVD PLAYER HAD INSTRUCTION BOOK, BUT LOST IT CAN YOU HELP WHERE I CAN LISTEN TO THE TV AND LISTEN TO CD'S?? THANKS, , JAY
    Scholar:
  • 135 Answers
Hi there!
If using an RF Converter you will have to tune whatever you connect to it onto UHF Bandwidth until it locks. You would tune it like you would tune any other station. So as an example tune a tv station onto CH1 and the DVD onto CH2 etc. Regards and good luck. JUS004
Posted on Apr 02, 2008
SOURCE:
Im trying to hook my denon stereo to my tv... can you help me??
What inputs does the TV have?
Otherwise experiment with these options:
DENON---------->>-------TV
Stereo jackplug phones out->>-RCA phono inputs.
RCA phono outputs->>-RCA phono inputs.
Stereo jackplug->>-AV.RF converter RCA phono inputs->>-ANT.in.
RCA phono outputs->>-AV.RF converter RCA phono inputs->>-ANT.in.
Nov 29, 2017 | Denon Audio Players & Recorders
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
Mar 22, 2015 | RCA Televison & Video
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Jan 02, 2015 | Televison & Video
Bought a ROKU XS needed a RCA CRF 907 TO CONNECT TO MY OLD SONY XBR 55' TV..DIDN'T HAVE ANYMOR
Hi, after a lot of searching I found all your bits but not too sure on the TV itself as it's not showing connections on the rear.
However as far as I can see, based on the device and your question, it looks like the standard old style coax goes from the CRF 907 TV OUT socket to your TV's ANT. IN socket.
I hope this helps.
May 05, 2017 | RCA Crf907 Compact Rf Modulator
Where is the coaxial for model number 57hc85 serial no 26101140 chassis no tac 506 we cannot connect a signal at all we bought a modulator rf but it's asking for asking us to connect 1 into the tv but...
After some research http://www.tacp.toshiba.com/tacpassets-images/models/51hc85/docs/51hc85_om_e.pdf There is no coaxial input for this tv. Also as far as the RF Modulator you unfortunatly are trying to use that incorrectly. The RF Modulator is used to convert the RCA or Red Yellow White cables down to Coaxile, not vice versa. However if you have an old VCR or better yet a cable box you would want to hook up the cable box then enter the TV using one of the RCA jacks, HDMI Jacks, or other inputs such as Svid. But easy enough if you have a vcr you can access cable through that as well, and make sure the tv is sat to the correct channel or input to access the VCR or other item.
Feb 04, 2011 | Toshiba 42H81 42" Rear Projection...
How do i use the ant. passthrough on tv2 in dual mode w/ dish dvr625
ANT. passthrough for an ant. connected to your 625 receiver will only work on tv 1. The only way to do this is to RF modulate your tv 2 coax to an RCA and hook the RcA cable to your tv2. then use another ant. to connect coax allowing you to pick up dish programing on an input and then going to the channels to enjoy local over the air programming.
Nov 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
No jacks in the back
This is a very basic TV with only a single ANT/CABLE/RF INput. If you intend to use a DVD player whose outputs are the yellow, red & white RCA, then you would need either:
1. an RF modulator similar to this one or
2. use an old VCR to accept the yellow, red & white RCA cables as INputs. The VCR would then have to be connected to the ANT/CABLE/RF INput using an RF patch cord. The TV wold then have to be tuned to either Channel 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | GE 25GT240 25" TV
Installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Jan 12, 2008 | Televison & Video
RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Nov 08, 2007 | RCA F27242GY 27" TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Ekse
