Question about Linksys Wireless-G WRT54G Router
I want to secure my wireless system so no one else can use it like my next door neighboor
    Scholar:
  • 50 Answers
It would help if you posted the exact model number of your router.
Either case, assuming it is the unit pictured in your post. the Linksys WRTG 54.
You will have to turn on WEP or WAP security protocol.
This is explained with screen shots at the following link:
then click on "User Guide" under more information on the right side.
This will open a PDF file that will tell you how to set up security ( i believe it is Chapter 3).
good luck,
djEnigma
Posted on Apr 01, 2008
  • Suresh Sundaramurthy Apr 03, 2008
    How is my Solution Inappropriate ?..
Where can I find wireless security cameras in London?
One of the best wireless security camera installation companies in London is WSA Solutions who have years of experience in dealing with the state of the art CCTV cameras for offices, homes, and other businesses.
Jun 20, 2016 | Home Security
What is the number that should be programed into the simon 3 security system for the central monitoring system?
To clear the tamper enter the code and off twice in a row. The central station number will be given to you by the company monitoring your alarm which will cost you between $29 to $49 a month
Aug 22, 2014 | GE Security Simon 3 Wireless Home Security...
Can any wireless door or window sensor be used with the ge simon
Sad to say but other brands of wireless door and window sensors will not work with the ge simon. Other sensors has different command patterns that it will not recognize the command coming from the GE Security Simon 3.
Nov 02, 2010 | GE Security Simon 3 Wireless Home Security...
I have a GE Simon XT. I arm the system. When I return several hours later, the front door doesn't beep when I open it. I have to close/open it again to register. Front door is Sensor 1, Group 10. What...
Can I assume it is a wireless contact we are talking about?
1.) Low battery in tansmitter. Does your keypad display a low battery trouble? If so, ensure you put system in test before replacing battery as not to generate a tamper alarm when opening contact.
2.) Relay in transmitter is sticking. Replace wireless contact.
Stewart
May 26, 2010 | GE Security Simon 3 Wireless Home Security...
Alarm wont sound
If your door is protected by a wireless transmitter your problem is most likely a defective switch or a grounded wire from the switch to the transmitter. To determine if the transmitter is working properly pop off the top of transmitter case by using a small blade screwdriver. If you look on the side of the casing you will see a small slot where the screwdriver is placed. Insert the blade of the screwdriver there and twist. The top of the transmitter will release. Inside you will see a small circuit board and battery. If an external switch is used you will also see 2 wires connected to the circuit board which then leads to the swtch. Using a very small screwdriver remove these wires. Now go check system status at your keypad. If the system recognizes the door as open then your problem is a bad switch or pinched wires that are grounding out the switch. If the keypad's status says the door is still closed the problem is in the transmitter. Sometimes these transmitters will be installed using an internal contact/switch.To know if this is the case on your door you will see only the transmitter mounted on or next to the door and a small magnet within a half inch or so on the opposing side. If this is the case your problem again is the internal switch. For replacement of external switches you can try going to a Radio Shack where they offer an assortment. Hope this helps.
Mar 30, 2010 | GE Security Simon 3 Wireless Home Security...
How do I remove the cover of an ADT home security panel to change the batteries
There is a plastic tab you will need to press to un-lock the door, it is located on the center rear of the unit, just be careful and don't pull too hard, it is plastic, this will expose the keypad and will require a code entered, you will need to pull this next cover down also ,again, another plastic tab holding it, should expose the area where there is wiring for a.c., ect, battery is inside compartment, need screw driver to open it, sometimes a screw was added to hold the doors, jfyi
Sep 29, 2009 | GE Security Simon 3 Wireless Home Security...
Driver door
try to find a neighboor or friend that can help. or just go online and learn how to fix it urself.
Apr 01, 2009 | 2006 Chevrolet Cobalt
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
94 jeep grand cheroke
If you remove the glove box you will find the alarm module behind it next to a relay box. If you unplug the module the Jeep should start.
May 21, 2008 | 1994 Jeep Grand Cherokee
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
