Question about Vacuums
Hoover Wind Tunnel 7500 Brush not Turning. I have replaced the Brush and the belt. The problem does not seem to be either to me. I believe might be a missing part. The place were the belt hooks on is a metal pole which never seems to grip the belt well. In fact it seems loose most of the time and slips on the brush, causing the belt to eventually burn up. Could there be a missing plastic or rubber piece meant to hold the belt taught  on the metal pole?
    Problem Solver:
  • 3 Answers
Check the Idler Pulley part Number 43241004 (Item 13 in the IPB)
http://64.49.205.183/v/u6451900.pdf
Posted on Jan 30, 2009
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
Mar 09, 2008 | Vacuums
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Edge of carpet went into carpet; was removed, but now all rollers on the unerside don't function.
You didn;'t say what the problem is, but I assume that the brush roll is not turning. Take of the cover over the brush roll, then you can get to the brush roll and the belt. The belt probably came off or broke. Best to replace the belt.
Jan 07, 2008 | Vacuums
Vacuums Logo
218 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
