Sony wega kp46wt520 problems
Won't turn on and 9 blinks. TV guy said it is zero detect error need GPCB for $425.00... Help!!
  • nansjs Apr 02, 2008
    Thank you. If you could tell me how to check the diode that would be great. The TV man warned me that one amp. could kill a person... so I am a little nervous, but 10.00 vs. 425. I'll give it a try. Also where to get the parts.
  • mshultz05 Apr 20, 2009
    The Tv does not turn on. But the stand by light flashes 9 times. What does that mean?
  • 8,617 Answers
Diode D6116 or D6301 on G board are open . Check the diodes and if open replace them that should fix your set about 10.00 if you need to know where to get the parts let me know and I will post the link. also tell ya how to check those diodes if you dont know how.
Posted on Apr 02, 2008
  • Sonny Berry
    Sonny Berry Apr 02, 2008
    you need to unsolder just one leg of each diode and lift it out of citcuit. Then place one lead of a ohms meter on each leg of the diode note the reading then reverse the meter leads on the diode. a good diode will have continuity in one direction and have no continuity in the other direction. If you get continuity in both directions it is shorted if no continuity in either direction its open either way change the diodes. Let me know the results of your test and I will then post the part numbers and ratings so you can order replacements. Be careful around the capacitors those can shock you if you touch their pins . They look like little towers in case you dont know just be careful not to touch the circuits where the capacitors mounted.
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega kp46wt520 no power up, 9 times it blinks red
You will need to replace the G board. You can try replacing the two diodes that usually fail, But because its a complex circuit with the zero cross detection the diode replacement never fixes the issue. Replacing or remanufacturing the G board is the only sure way to fix that issue.
Nov 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony TV stuck in stand by mode
the 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
Sep 06, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-32FS120 - 9 Blinks
I just fix one like this one for $200.00 usually is $275 you have problems in the zero cross detector inside the tv
Jul 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My big screen sony kp46wt520 don't turn on.
9 blinks error is for zero crossing error
your problem is 2 diodes on the G board that are leaking
D6116 8-719-074-43
D6301 6-500-567-21
One of these is surface mounted u will need a guy with soldering skills to replace it without damaging the board
Mar 01, 2008 | Televison & Video
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
486 people viewed this question
Top Televison & Video Experts
