Need a place to buy lamps for a onkyo t 9 tuner. they are for the the analog meter and tuning dial.
  • 4,234 Answers
Try MCM Electronics (mcmelectronics.com). They have all types, one of which will fit your unit.
Dan
Posted on Apr 01, 2008
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
How Ido tune it l have no manual.Can you please help.many thanks
Radio With Manual Tuning - Alibaba
www.alibaba.com > Automobiles & Motorcycles > radio > radio with
Radio With Manual Tuning, Buy Various High Quality Radio With Manual TuningProducts from Global Radio With Manual Tuning Suppliers and Radio With ...
Help Guide ' Tuning in an FM radio station manually ... - Sony
https://www.sony.co.uk/.../emanual/.../TP0000016777....
Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
Tuner (radio) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Tuner_(radio)
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
[PDF]Tuning into a Radio Station - Onkyo
Dec 16, 2015 | Audio Players & Recorders
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
Miniature dial panel bulbs for Onkyo TX-2500 Mk II
Chances are they are LED. Check with Radio Shack or online you can check www.1000bulbs.com Hope this helps
Sep 21, 2009 | Audio Players & Recorders
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Onkyo tuner
the model is at the back panel it usually starts with a TX or a T. go to onkyousa.com or call 1-800-229-1887 were here to help.
Oct 29, 2008 | Onkyo TX-SR605 Receiver
HELP: Onyo Remote Does Not Recognize Receiver when using Cable
Since you have the cable connected to the reciever thru the HDMI, you may have accidently changed the input source of the reciever from HDMI or digital to analog.
When you have the reciever set to listen to the cable, check the input mode and make sure it is set to use the HDMI or digital input and not the analog.
The rca jacks are analog, and they worked, so I think you have just solved your own problem without realizing it.
Let me know if this works and if so a good rating would be appreciated. Thanks and have a great day
Jun 16, 2008 | Audio Players & Recorders
Tuner Problems
OK the tuner may be causing these problems, however first I would like you to go to your menu and set the RF pickup to antenna (This will allow analog channels) then come out of the memu and select a channel in the analog range channel 4, 7, or 9 try to tune in these channels. If this fails then you may have tuner problems the only way to be sure is to use a RF signal generator to send RF through the tuner and see if the video and audio being carried on that signal comes through. Sometimes the Internet connect gets messed up when the TV does not have the proper RF filters this may be your case. Try this use a Cable tv set top box and just set your TV to channel 3 for cable. This should Isolate the TV from the Internet cable modem and provide the signal needed by the TV.
Aug 19, 2007 | RCA 32V550T 32" TV
35 people viewed this question
 Grubhead
Grubhead
