MFC_5840CN Will not print, not showing
MFC_5840CN Will not print, not showing error message, reads full of all color ink. I'm using a mac OSX10.4.11 Help!
  • nevil796 Apr 01, 2008
    Yes, it still copies and print faxes. Seems the problem is just printing from the mac
    Yes, it's compatible. It has worked before
  • 871 Answers
Is it compatible with your OS? have you tried searching for a comptible software and driver for that OS>?
i would assume that your printer is using a usb connection right.
then the most that you can do is try to jump from one usb slot to another so that your computer will be able to detect that the printer is connected.
with regards to ser71 posts, his steps are good and in essence to be followed.
feel free to post any reactions you have...
Posted on Apr 01, 2008
  • earl norman llanera
    earl norman llanera Apr 01, 2008
    yup!
    try to install new drivers for that. that will surely work
    Master:
  • 788 Answers
Does it copy and print internal reports and test pages but not print from the mac? Does it still print faxes?
    Genius:
  • 3,422 Answers
HI,
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no.
i will be posting out more info..
Goodluck..
  • Priya darshan Apr 01, 2008
    IF you cannot print from Mac then please do the following steps to fix your problem:
    In order to correct this problem, uninstall the
    printer driver packages installed for printers you do not use on your
    system. Macintosh® OS X comes pre-installed with other packages automatically. This can sometimes cause conflicts and are not generally needed.
    In order to remove the packages, you will need to begin by opening
    the hard drive that contains the OS X system software or the Root
    folder. Normally double-clicking on the Macintosh Hard Drive icon will open automatically to the Root folder.
    1. Double-click on the Library folder.
    2. Double-click on the Printers folder.
    3. Select and delete the folders for Epson, Cannon and HP.
    NOTE:Do not delete any other items from this folder since it may effect operation of other items that are connected to the computer.
    1. Empty the trash.
    The other software is removed from the system. You should re-select the Brother unit from the Print Center and try printing.
    Goodluck,
    Please don't forget to accept the solution as fixya..
  • 818 Answers
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
Posted on Nov 02, 2007
Mix-it-up
  • 832 Answers
SOURCE: Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Posted on Jan 10, 2008
  • 8 Answers
SOURCE: Brother MFC-5840CN
Press Menu, * 2864. That puts in in maintenance mode. If it flashes error 48, the flat ribbon to your head is broken. You'll need to replace the entire head assembly. Press 99 to leave the maintenance mode.
Posted on Sep 22, 2008
SOURCE: how to install LAN Brother MFC-5840CN on Windows 7
I plugged the printer into my laptop and let windows 7 install the drivers. It couldn't get the correct driver for the printer itself. Let Windows fix the problem. I then unplugged the printer and performed a network install, Windows picked up a driver was already installed and then use this driver. Can now print via a network or locally.
Posted on Mar 20, 2010
  • 420 Answers
SOURCE: Ink level status on black ink is not accurate
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Posted on Sep 15, 2010
The black will not print. I have replaced the cartridge with two new ones. Color prints ok. Brother mfc 5840cn
please perform head cleaning to see if there is any ink out.. goto ink management and select head cleaning... after that goto ink management and print the nozzle check.. see if there is any black ink out...if no ink out..then more probably your print head is badly clogged..and you will need to get it replaced.
Jun 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
MY MFC 5840CN ERROR MESSAGE READS "UNABLE TO CLEAN" DOES NOT APPEAR TO HAVE ANYTHING JAMMED OR STUCK INSIDE. WHAT DO I DO?
That error means the ink absorber box is full, no more room for waste ink. There are instructions on this site to reset, but best to have the box replaced at a shop and reset. The whole job about $80.00
Oct 12, 2009 | Brother DCP 115C All-In-One InkJet Printer
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Get paper jam error on Brother MFC 5840CN
are you using brother oem ink? generic ink gives lots of problems
Dec 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Nov 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
MFC-5840CN "unable to clean" and "machine code 50"
you have to fix the encoder strip into right position within the ph carrier! do push the head left/right to see if there are waves infront of it. if so, fix the strip into position!
BTW:
If you refill your carts use 2ml glycerol (from drugstore) with 10ml dye-ink: mix well before refilling. For bk use 1,5ml glycerol with 20ml bk dye-ink.
The glycerol prefents the ph/nozzels and tubesystem from drying up!
Apr 21, 2008 | Brother MFC-5840CN All-In-One InkJet...
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
First things first:
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
82 people viewed this question
k24674
jasbo
jasbo
