Question about Microwave Ovens
Help, my Panasonic NNA724M Combination Oven will no longer microwave. I can set the microwave going but after 20ish seconds the microwave stops and timer is replaced by the clock, without any audible warning. I've attempted to do numerous cycles at the 20ish seconds with a glass of water to see if the microwave is working at all but have had no success. It appears that although the timer does run for a limited time the microwave does not work, but I can not explain why the timer cancels after a short period. The oven & grill parts are still working correctly. Any help would be appreciated. Thanks.
  • Tartarus Apr 02, 2008
    thanks for the advise. I was hoping that it might have been just a simple PCB replacement, but I think I'd better call in the experts.
    Many Thanks, Tartarus.
  • Microwave Ovens Master
  • 9,086 Answers
This is an inverter model, and when they stop after 20 seconds, it usually means a problem in the high voltage section, either the inverter or the magnetron.
If you don't have experience troubleshooting high voltage inverters, I recommend calling a pro.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 02, 2008
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
Panasonic nn-c2000w microwave oven no longer heats anything up and turns off after less than 30 seconds
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 20, 2011 | Panasonic Microwave Ovens
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
My panasonic microwave oven is not warming food or water,set time 30secs or above it stops by itself
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Nov 23, 2009 | Panasonic NN-T990SA Microwave Oven
My panasonic microwave stops working after 6
If it stops after 7 seconds, it has a problem with the inverter.
Aug 09, 2009 | Panasonic Microwave Ovens
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Will not heat
heatman101
yysrsj
Sep 02, 2008 | Panasonic NN-S962 Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Stop after 5 seconds
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
May 24, 2008 | Panasonic NN-P294WF Microwave Oven
Microwave Ovens Logo
314 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
