Question about HP vs19 (Silver) 19" LCD Monitor
HP vs 19
My power led was going on for few seconds then it comes off with with no display and this happend after less than 2 years of using . I have checked the fuses and the rectifier they were ok and i replaced the main capacitor , but i have no schematic to check the regulator or other components ,
I hope i can find help here ,,
  • 180 Answers
You can desolder the B+ line to check the power back to on condition. If the power lit on.It is the int cap inside the FBT has shorted.
Happy trying.
Posted on Apr 09, 2008
  • Ajemy  Rashid
    Ajemy Rashid Apr 17, 2008
    I am sorry is so set LCD or CRT ?
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
Dec 20, 2015 | LG Televison & Video
How do I troubleshoot my motherboard on my HP Pavilion a1020n. This is my motherboard PTGD1-LA.
A) Power Supply.
One of the leading causes of computer failure.
LED lights come on? Fans spin, or spin a few times, and stop?
Bad Power Supply. Weak voltage power rail.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is. (Older Processors such as Pentium II's for example, use less)
No Processor operating = No Signal on the monitor.
No video signal.
But if you do think it's a problem with the Ol' Goldfish 3, look at the Electrolytic Capacitors on the motherboard.
Sep 22, 2010 | Computers & Internet
Our one year old monitor comes on, but then goes black after just a few seconds. it is not the graphics card. I hooked it up to another computer and it did the same thing.
If the monitor power light on remains on, either the monitor itself or VGA cable is faulty. Move the cable to see if there is any change on the display. I'd suggest changing the cable - less expensive than a monitor. If not the cable, the monitor is faulty.
Jul 13, 2009 | HP w19 19" LCD Monitor
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
My HP w2007 19" lcd monitor when turning on from sleep mode turns on for a second than turns off is this a virus
No, no virus. This is usually a power supply problem. I see this thing all the time with LCDs. If you montior is less than 3 years old Dell should replace it for you.
Just go to this link:
Type in your PC's service tag and click send them an email or do what I do and use the online chat feature. It is quick and easy. You'll need to give the very log serial number off of the back of the monitor (usually begins with the letters MX, CN, or MC).
However, if it is older than 3 years you may be stuck buying a new display. Luckily there are some great deals now on new LCDs....let me know how it goes.
Mar 08, 2009 | HP w1907 LCD Monitor
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
its so simple problem on screen what come no signal rigt
so u have to do this just chek ur monitor cable its not pulg in cpu
so reconnet ur monitor cable in your cpu
thnx using fixya
Mar 30, 2008 | HP f1905 19" Flat Panel LCD Monitor
P900 standby problem
CRT a relic Cathode RAY TUBE , monitors, why use this?
this monitor is old but has the menu button, see that?
push that, see OSD menu, sure
then turn off all power saver-modes and sleep timers there.
the manual is free to read, RTM? (if googling a week is fun)
circa 2004? HP has no manuals in english. on this mon.
i can only find the manual in Chinese or for hard cash !.
wow, why not upgrade to LCD (LED) displays, 2010 or newer?
be best. for you .!
use that menu button on the front if the monitor
that is the cure !
Nov 26, 2017 | HP Compaq P900 (Pearl, White) 19" CRT...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
HP vs19 (Silver) 19" LCD Monitor Logo
51 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
