Question about Gigabyte GA-6WMMC7 Motherboard
Sound interferance when plugged into m/board
I have a pc surround sound system that when plugged in emmits scratching and squeeking aswell as sounds, please help me its driving me nuts
  • 99 Answers
Is your sound card onboard? try to do the ff..
1. try to reinstall the driver.
2.clean the knob of your speaker, may be the volume of your speaker dirty ,clean it or try onother speaker
3.try to use another sound card ,may the onboard is defective already.
Posted on Apr 02, 2008
SOURCE:
Is it possible to get sound from my tv stations aswell on this thing or does sit just work for the dvd player
your tv is stereo sound so the only way to get surround is to press the 2.1/5.1 button on your norcent remote
Feb 17, 2012 | Norcent Technologies DP1800 System
Logitech X-530 speaker set plugged in as per instructions delivering sound from only front speakers and sub woofer. Nothing from centre and rears. XP system with ASRock ALiveDual-eSATA2 mother board....
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
Aug 08, 2017 | Logitech X-530 5.1 Surround Sound...
How do I connect a samsung c555 home cinema system to a LG 42LD450 42 inch tv so that i can get sound out the built in freeview? also cant seem to get sound out my PS3? I have connected the video output...
Use an optical cable from ps3 to surround sound and hdmi from ps3 to tv.... But I can't get my samsung surround sound to come out of the tv with built in freeview either. Just wondering if you figured it out. Cheers
Nov 14, 2010 | Samsung Audio Players & Recorders
How can I connect my Panasonic SA-HT540 to my PC in order to get the full 5.1 surround sound out? I currently have an auxilery lead running into the 'Front Speaker Out' on the back of my PC from my...
If your sound card supports 5.1 and your Panasonic supports 6 channel input then you should be able to do this with extra cables and changing some settings on your computer. Your sound card should have three "headphone" plugs on it. The cable you are currently using for front speakers is likely a 3.5mm to RCA cable. You will need two more of these. With these you will have your 6 channels, or, 5.1. All you do then is tell the sound card driver that this is how you want it to output and it will tell you which cable to hook where.
Otherwise, you have have a single coaxial digital out on your sound card and this is probably best.
Which you use should depend on which component has a higher quality DAC.
Jan 14, 2010 | Panasonic Home Theater System System
My samsung sound surround system is 1000watt and im not benefitting from the volume< it is connected to my tv but how do i turn the sound surround louder by using the volume on my tv aswell as the sound...
You need to program the TV remote to work the surround sound.  You gotta select a button that says AV or Aux on the remote.  Then you gotta input some #s so the TV remote can send the proper infrared beam to the surround receiver.  The codes will be in the users manual to operate different brands of electronics.
Oct 25, 2009 | Audio Players & Recorders
Sound is coming from the surround sound system but not from tv
hiya
if you have sound from the tv aswell you will experience a slight delay in the audio.....
do you have audio from the tv to the system ?
Feb 23, 2009 | Technics SA-DX1050 Receiver
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Jan 18, 2009 | Samsung HT-Q100 System
Computer speakers are buzzing
Common humming sounds from computer sound systems stem from the follwing:
1) Interferance with other electrical componants / devices
Solution: EMF / Radiostatic shielding may provide the solution
2) Defective componants
solution: try the hardware in another PC, if it still hums, your board / plug-in compants may be defective.
3) Jack(s) - Headphones / speakers have loose connection
Make sure everything is plugged in securely, and your jacks have not been damaged, also make sure you are plugged into the correct ports.
4) Microphone boost / auxiliary settings
check your sound settings, disable any ports you aren't using. Line-in, Aux, CD-rom, Digital Input.. if they aren't being used, they may be creating "whte" static in the lines. Muting them, or disableing them in the sound settings for your device may provide the solution..
5) It has been known to happen that certain CPU / Case / Power supply fans emmit a sonic frequency through the speakers due to EMF expulsions from the electro-magnetic motor. This is rare, but is possible, Disable the case fan to determin if it's the culprit, swap power supply, or CPU fan to determin if they are the issue.
WARNING: Never run your PC without the CPU fan in full operation, Never run the PC without your Power Supplies fan in full operation: This can lead to DAMAGE to your PC.
On a personal note: My card has several different ports, make sure you are plugged into the correct port, and muting the Aux cleared the humming in my computer's sound system.
Jan 13, 2009 | Philips MMS 321 Computer Speakers
Desktop sound card
i believe you have something connected wrg since your pc only requires one jack from sound card. to you subwoofer then its seperated to he others. read the book on *********** board to see if you can change your options on the sound configuration.
Nov 28, 2008 | Logitech X-530 Computer Speakers
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Gigabyte GA-6WMMC7 Motherboard Logo
66 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
