Question about Sony Cybershot DSC-T200 Digital Camera
Red Eye 90% of pictures taken with the DSC-T200 display red eye. I have tried all red eye settings etc.. and cant seem to resolve. It is almost impossible to get a clean close up shot without red eye. Any ideas or suggestions would be greatly appreciated. Thank You.
  • Gert-313 Oct 31, 2008
    I have the same problem with red eye on my Sony T200. I have had it for a few months now and it seems to be getting worse. Can't take a picture without having the red eye problem. I take too many pix to have to fix each of them individually.
  • 871 Answers
I have a suggestion,
you can use Picasa2 to get rid of the red eye from your pics. however, this is installed on your computer and whenever you will take pictures, there will still be red eye. Picasa2 is very easy to use and you can get rid of the red eye in only matter of seconds.
download Picasa2 here
Posted on Apr 01, 2008
SOURCE:
Everytime I snap a picture, the camera flashes three times. Help!
The camera is in Red-eye Reduction mode. The preflashes are intended to get the subject's pupils to contract, reducing the red-eye look.
Press MENU to display the menu. Press right-arrow to select the toolbox icon (Setup). Press the arrow keys to select Red Eye Reduction, and turn it off.
May 14, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Many of the photos taken from the cam do have red/brown.. colored eyes.. goods photos are often discarded due to this.. pl help me..for free.
go to menu bar of the Cam.. there u will fine an option call "red eye correction" please do make use of the option and no more discardings... cheer!!
Jun 26, 2009 | Sony Cybershot DSC-T200 Digital Camera
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Red eye issue
You can just try to turn it off, just click on the menu button and go to the third page then you will see an eye icon, click on it and then press the button off, ok i hope this helps.
Dec 16, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
How can i reduce the Red eye in W35 ?
press menu and go 2 camera and go down 2 red eye reduction then turn it on
May 19, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Red eye
This camera is bad for red eye. It's just a problem that happens when the flash is so close to the lens. Red eye occurs when the flash illuminates the subject's retina.
The only solution, really, is to add an external flash that's farther away from the camera lens, which is not an option with this camera. The other, is to get better at taking photos without flash. Higher end cameras have better ways to deal with the red-eye, but these usually involve preflashes that close the subjects pupils (by blinding them with a preflash) before the actual exposure is taken. The Sony DSC-U30 has it as a feature, but it doesn't work very well, I've found. When it does work, it's a nice compromise as it gets rid of the red eye, but it also introduces a delay between pressing the exposure button and the actual taking of the photo.
Unless the light is very dim, I don't use flash with this camera.
After you've taken the photo and have downloaded it, there are ways to edit the red eye out that can be pretty effective.
Dec 24, 2007 | Sony Cyber-Shot DSC-U30 Digital Camera
Red eye reduction
while in record mode, press the flash/up button repeatedly until you are in red-eye reduction mode. red-eye reduction mode should greatly reduce the problem when enabled. If this does not work, the software that came with your camera (and most photo editing applications) include a red eye reduction/removal filter.
hope this helps,
trin
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
DSC-P72 using Flash
Hi, While I do not have a P72, I find this problem odd. Most flash cycle times are so rapid that your grandaughter could not possible close her eyes in that time period (the travel time for the flash to fire and be reflected from the child's face is far faster than a human blink). The problem may be in pre-flash and not the flash itself. So that redeye-reducing "feature" may be responsible for your problem. Does your camera have a redeye reduction mode on the flash?
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Red-eye problem still existant in the F505v?
Reports thus far are very favorable with regard to a lack red-eye problems and the red-eye reduction system. Many have said thus far that they usually do not need to engage the red-eye reduction flash.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
133 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
