Question about Vivitar Vivicam 5388 Digital Camera
Lens wont go back in
The lens is remaining out after i've turned the camera off, and when i turn it on it doesn't come out fully and the lens cover doesn't open.
  • aaateam Dec 10, 2008
    Lens will not go back in at all. I have tried everything I can think of.
    With that said, since the lens will not go back in, when I turn on the camera, nothing happens, no matter what I try to do. Help!
    Sergeant:
    Champion:
  • 333 Answers
Probably grit in the mechanism. That happened to my Olympus, but after frequent re-trying eventually the problem cured itself. It is unlikely that a repair will be economic as the price of digital cameras is so low.
Posted on Apr 01, 2008
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
When I turn on the camera the lens comes out and then retracks and it says to turn the power off and on again. when I turn the camera off it says the same thing
Hi, I have to say that's a problem I've seen fairly often with the Sony W320. My suggestion is to take out the battery and make sure it's fully charged then put it back in. If that doesn't work I'd contact Sony.
May 12, 2011 | Sony CyberShot DSCW320 Digital Camera
Olympia fe-340 won't fully turn on
You have a bad lens, you should take into a camera repair shop. The only other thing that can be possible is the cable from the lens to the camera man board may have not be making proper contact.
Jul 02, 2009 | Olympus FE-340 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Battery warming up the camara
Was your camera working before you put the new battery? if yes, then its possible some dirt or grit has got stuck between the lens and the body and therefore you motor might be warming up.
Since you 've bought a new battery, I dont think It may not be the battery, the way you are explaining. It could be the lens motor itself, since its warming up.
Try to do the following: ( I 've got this checklist from the forum itself)
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
6: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Try the above and let me if its any help.
Best of luck
Mar 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Panasonic tz3 cover gets stuck
Common problem with TZ3. You can try to lub lens cover using graphite lub. Use it sparingly and after lens works, wipe off excess with dust cloth. Be sure not to get any on lens itself.
If lub doesn't work, you can pull out the lens cover altogether and find a manual lens cap the will fit.
The other option is to sell it on ebay to a repairman in a auction and replace it with another working used ones. Keep your accessories and by a used one cheap without accessories.
Nov 28, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Casio EX-Z55 wont turn on after lens error
A lens error is something that can only be fixed my sending in to the repairs department. There is nothing that can be done at home to fix that.
Nov 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Vivitar Vivicam 5388 Digital Camera Logo
44 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
