Question about GE PSS26SGR Stainless Steel Side by Side Refrigerator
Dispenser not functioning & control panel inside turned off
I noticed this morning that my fridge will not dispense water or ice whatsoever. The lights on the display itself are on and you can toggle between ice/water, etc. but nothing is dispensed when the switch is pushed in. Upon noticing that, I opened the refrigerator door and noticed the control panel up top was completely off (no lights). Out of curiosity, I started pushing the buttons and when I hit the "colder" button for the freezer or fridge side, it would blink 000 on both read outs about 3 times and then turn off again. The strange thing is this was working fine just before I went to bed the night before as I grabbed a glass of water before calling it a night.
I unplugged and plugged the the power supply, but no luck. Any ideas what may cause this and if there is a quick fix?
Thank you.
-Matt
  • mindzeye77 Apr 01, 2008
    Thank you Master_Tech. How much is the control board if I need to replace it?
  • mitch0808 Jan 13, 2009
    We have a similar problem. The water dispenses, the ice maker works just fine, all other controls work as they should. However, the ice dispenser button does not dispense ice, not crushed or cubed. We have taken out the motor, tried another motor from another refrigerator, and still nothing. Is there a relay switch, or something that could have gone bad. If so, where do I check?
  • 770 Answers
You have a bad control board in the rear of the unit ...>>>>> To verify this check for 13.5 vdc on red and black going into the display board?? since your dispenser is not working the control board is most likely not working. puill the refrig from the wall and remove the cover plate it is square about 5"X6" you will see the control board thew part # for this is WR55x10552 if you need to replace it let me know
Posted on Apr 01, 2008
  • Gary Davd
    Gary Davd Apr 01, 2008
    go to www.apdepot.com and punch in the part number they will ship right to your door This Board is a known problem with this model.
    Also please rate the call when you are finished with any questions
    Thanks Gary
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Why has the water dispenser stopped working all of a sudden. Do the lines freeze up or is there an on off function on the control panel
Without knowing what make / model fridge it is nearly impossible to say , however, most domestic fridge have a water tank in the base of the food compartment which stores the water before going into the freezer dispenser. Have a look behind the crisper drawers for it. If the food compartment is too cold, this tank can freeze up and stop water from going into the dispenser. Is it still making ice? If so, the water valve which is normally 2 parts (1 for ice making and the other for water dispensing) may have failed.
Apr 09, 2015 | Refrigerators
Why is my GE profile fridge no longer dispensing ice? Can I fix this myself or do I need a professional.
Ice dispenser doesn't work
  1. Dispenser control board If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  2. Water inlet valve & low water pressure from house supply If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  3. Water tube in door is frozen If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  4. Dispenser switch If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  5. Door switch If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Search Over 2 1 Million Appliance Parts
Aug 19, 2014 | GE Refrigerators
Fridge question
  1. Water inlet valve & low water pressure from house supply
  1. Water tube in door is frozen
  1. Dispenser switch
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door light, on/off switch, water and ice dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it.
if you are still having trouble please respond with a model number
Apr 15, 2009 | Refrigerators
GE PSS26SGR Stainless Steel Side by Side Refrigerator Logo
476 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
