Question about Nintendo Wii Console
Wii freezing up
On my nintendo wii it will let me use the controller to get all the way to the game but then it wont let you swing like its not picking up the sensor once your in the game.. but the sensor works cause i use the controller with the sensor to get to a particular game like throught the menu and everything.. This is happening on all our wii games.. It seems like its controller one, I have tried reseting the remotes but I think you have to use remote 1 for remote one always.. if that makes any sense? i would love any input thanks im kinda technology illiterate.. Ha
Thanks Ashley
  • 34 Answers
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 06, 2009
    Scholar:
  • 119 Answers
Hi Ashley,
It sounds like the accelerometer in your Wii Remote is not working properly.
The "point-and-click" stuff like the Wii Menu use the WIi Remote's camera (which is behind the dark part on the front of the Wii Remote). The motion-sensing for swinging, tilting and other motion uses the accelerometer in the Wii Remote.
Wrap your Wii Remote in a towel and give it a whack against your knee (not so hard as to injure your knee) - sometimes the accelerometer part gets "stuck" and needs to be jarred out of position.
If that still doesn't work, then go to Nintendo.com, click Support, and go to the Wii Troubleshooting section for more options.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Also, you don't have to use the same remote as #1. The first remote that is activated will become #1.
You can also push the Home button on the Wii Remote, then point to the bottom (where the battery levels are shown), press A, then click on Reconnect. It will tell you to press the 1 and 2 buttons on each remote in the order you want them to appear. Press the 1 and 2 buttons on the remote you want to be #1, wait for the remote to sync (the Wii will make a happy nosie), then do the same for the remote you want to be #2, etc.
Posted on Apr 05, 2008
Will not swing when playing tennis on Wii Sports. It was working previously.
if you are using a wii motion plus, try placing it on the ground for about 5 minutes, and if that doesnt work call nintendo.
Dec 08, 2009 | Nintendo Wii Remote Controller
Our wii sport dvd works and you can naviagate to a game, but when you go to swing at a ball it will not work. Batteries are fine.
I have had a problem of this manner before, Does this problem occur with the same controller (wii remote) with each game requiring Movement of some sort. If so, then your Controller's bluetooth is damaged. It's a possiblity someone dropped it or the solder piece became loose in someway. I recommend sending it to nintendo for a replacement or buying another Wiimote (wii remote)
Nov 17, 2009 | Nintendo Wii Sports for Wii
Wii remote works but not for wii sports
If you're wii remote works as a pointer but not when swinging it then it is a problem with the accelerometer inside the wii remote and not the infra red bit on the end. Good news is its usually just stuck as mine was. Nintendo recommend turning the remote upside down and giving it a few taps on the palm of your hand. Worked on mine and saved me £30 as i was about to buy a new one.
Aug 04, 2009 | Nintendo Wii Remote Controller
Remote swinging problems
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 17, 2009 | Nintendo Wii Console
Wii remote won't let me swing or box
if the remote sensor doesnt work, then it wont register with the game console. there is sort of an accelerometer in a wii mote that can sense the changes in angle and height and things like that. that accelerometer could be broken due to dropping of the controller(unlikely) or overshaking(very unlikely) or just bad production(sort of likely). just call the nintendo customer service and confirm the problem with the controller and ask if it is possible to refund the item for a new one or you could just buy a new wii mote. also, you could try using a friends wii mote to make sure that your system is recognizing the controller.
Oct 12, 2008 | Nintendo Wii Console
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
Wii game freezing at same location. urgent!
It could be the nintendo wii itself, try and find a gaming repair shop and see what they say, if it is the wii they will repair it for free or might cost a bit, chances are it might just need cleaning on the inside (dust) hope it gets sorted out
Jack
Apr 22, 2008 | Nintendo Wii Console
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
Wii control
unplug the unit from the wall and try it again.
Dec 31, 2007 | Nintendo Wii Console
Wii sports
unplug and plug unit back in/.
Nintendo Wii Console Logo
186 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
