Question about Lands Phones
Where is area code 617 please? - Lands Phones
  • 589 Answers
Towns in Massachusetts:
BELMONT
BOSTON
BROOKLINE
CAMBRIDGE
CHELSEA
EVERETT
MILTON
NEWTON
QUINCY
SOMERVILLE
WATERTOWN
Posted on Apr 01, 2008
How do i fix my 1997 mercury grand marquis my air bag light flashs code 41
B1941 41 RH primary crash sensor feed/return circuit open GO to DTC B1941.
DTC B1941: RH PRIMARY CRASH SENSOR FEED/RETURN CIRCUIT OPEN- LAMP FAULT CODE 41
Normal Operation
The voltage at Pin C276-16, Circuit 617 (PK/O) is set by the air bag diagnostic monitor to be slightly less than battery voltage. Circuit 617 (PK/O) is connected to Circuit 624 (Y/W) inside RH primary crash sensor. Therefore, the voltage at Circuit 624 (Y/W) and air bag diagnostic monitor Pin C277-24 should be the same as the voltage at air bag diagnostic monitor Pin C276-16, Circuit 617 (PK/O).
The air bag diagnostic monitor periodically pulls the voltage at Pin C276-16, Circuit 617 (PK/O) low to verify the connection to Pin C277-24, Circuit 624 (Y/W). If the voltage at Pin C277-24, Circuit 624 (Y/W) does not pull low as a result of this test, the air bag diagnostic monitor will store in memory DTC B1941 and flash lamp fault code 41 on the AIR BAG indicator. If the connection between Pins C276-16, Circuit 617 (PK/O) and C277-24, Circuit 624 (Y/W) is later serviced, DTC B1941 will be stored in memory.
Possible Causes
Failure to get low voltage at Pin C277-24, Circuit 624 (Y/W) during the test can be caused by:
  • an open circuit in the wiring harness in either Circuit 617 (PK/O) or Circuit 624 (Y/W).
  • an open circuit inside RH primary crash sensor across Circuit 617 (PK/O) or Circuit 624 (Y/W).
  • a short to battery or ignition voltage in any of the Circuits 617 (PK/O), 619 (PK/W), 624 (Y/W), 625 (Y/LG).
May 22, 2017 | Mercury Cars & Trucks
How to closed zero dial in this phone set
phone circuits included electromechanical relays which imposed limitation on the speed of dialing a digit, and therefore dialing a complete 10-digit telephone number could take up to ten seconds, during which hardware resources had to be dedicated to a circuit. The Bell System organized the numbering plan to minimize the cost of providing automatic dialing to large population centers. The second digit of all area codes was 0 or 1, while the second digit of the exchange triplet was never 0 or 1, thus facilitating the recognition of whether a user was dialing a full 10-digit number or merely dialing within the local area code. In this coding scheme it was not yet necessary to dial a leading 1 for access to long distance circuits to other area codes. In some regions, local numbers were 7 digits, or occasionally less, but a toll call within the area code required a preceding 1. Area code 617 in eastern Massachusetts used this system in the early 1970s, while the Chicago area (312) did not. In the Chicago area, one could call the Boston area by dialing only 10 digits, while in Boston, to call Chicago, one would be required to use 11 digits, including the prefix 1.
Dec 19, 2013 | NEC Lands Phones
I NEED THE CODE TO AN LG LCD TV FOR THE BRIGHTSTAR BR100Z
here is a list of tv codes hope this helps
Admiral 500, 614 , 902, 615, 610, 501
Advent 911, 932, 933
Aiko 900
Akai 601, 903, 922
AOC 601, 617, 103
Apex 000, 618, 604
Audiovox 100, 901, 900, 101
Belcor 617
Bell&Howell 620, 611
Bradford 901
Brockwood 617
Broksonic 902, 614
Candle 601, 619
Celebrity 605
Changhong 618
Citizen 903, 601, 619, 900
Clairtone 103
Concerto 619
Contec 901, 103
Craig 901
Crosley 303, 301
Crown 901
Curtis Mathes 400, 301, 620, 100, 500,
903, 621, 606, 619, 611,
603, 102, 402, 401, 405
CXC 901
Daewoo 100, 617, 900, 101
Daytron 617
Dumont 700, 617
Durabrand 902, 901, 201, 614, 615, 914, 918
Dynex 614
Electroband 605, 103
Emerson 620, 902, 614, 901, 200, 201
607, 617, 615, 602, 103, 101
Envision 601
ESA 901, 201, 601, 903
Fisher 620, 801
Fujitsu 615, 300
Funai 901, 615, 201
Futuretec 901
GE 400, 202, 100, 200, 607
608, 802, 402, 401, 405
Gibralter 700, 601, 617
GoldStar 601, 607, 617, 619
Grundy 901, 615
Haier 914, 918
Hallmark 607
Harvard 901
Hitachi 606, 619, 611, 005, 916
ILO 921, 925, 609
Infinity 301
Inteq 700
Insignia 614, 303, 201,301, 909, 919, 920, 934
JBL 301, 000, 604, 618
JCB 605
JC Penny 400, 609, 202, 903, 601, 607,
608, 617, 800, 402, 405
JVC 701
KEC 901
Kenwood 601, 617
KLH 618
KTV 901, 601, 103
Konka 904, 001, 304, 002, 003
LG 619, 910, 700
Logik 611
Luxman 619
LXI 400, 301, 620, 609, 607, 402
Magnavox 301,302, 303, 601, 615, 617, 803,
905, 906, 907, 908, 909
Majestic 611
Marantz 301, 601
Matsushita 004
Megatron 607, 606
MEI 103
Memorex 620, 004, 614, 104, 607, 615, 611
MGA 104, 601, 607, 617, 500
Midland 400, 700, 202, 402
Minutz 608
Mitsubishi 500, 104, 607, 617, 601
Motorola 500, 802
MTC 903, 601, 617, 619, 103
Multitech 901
NAD 609, 607, 603
NEC 601, 617, 619
Nikko 601, 607, 900
Noshi 800
NTC 900
Olevia 923
Onwa 901
Optimus 620, 004, 603
Optonica 500, 610
Orion 902, 614, 615
Panasonic 004, 202, 802, 610
Philco 301, 614, 601, 606, 617
Philips 301,302, 303, 601, 615, 617, 803,
Pilot 601, 617
Pioneer 603, 600
Polaroid 400, 910, 913, 915, 917, 920
Portland 617, 900
Prism 202
Proscan 400, 402
Proton 607, 102
Pulsar 700, 617
Quasar 004, 202, 610, 802
RadioShack 400, 620, 610, 901, 621
607, 617, 619, 402
Realistic 620, 610, 901, 601, 607, 617,619
RCA 400, 617, 800, 612, 600
402, 403, 401, 404, 405, 623
Rhapsody 103
Roomconx 614, 615, 902, 924
Runco 700, 601, 616
Sampo 601
Samsung 903, 601, 607, 617, 619, 930
Sansui 614, 902, 615
Sanyo 620, 801, 931
Scotch 607
Scott 902, 901, 607, 617, 615
Sears 400, 301, 620, 609, 607
615, 622, 801, 201, 402
Sharp 500, 610, 501, 929
Sharp (LCD) 912, 929
Shogun 617
Signature 611
Simpson 803
Sony 605
Soundesign 901, 607, 615
Squareview 201
SSS 901, 617
Starlite 901
Supreme 605
Sylvania 301, 601, 201, 901
Symphonic 901, 201
Tandy 500
Tatung 802
Technics 004, 202
Techwood 202, 619
Teknika 301, 901, 104, 605, 617
615, 619, 611, 900
TMK 607, 619, 602
Toshiba 620, 609, 903, 613
Trutech 101
Victor 701
Vidtech 607, 617
Vizio 927
Wards 301, 610, 601, 607, 608
617, 615, 619, 611
Westinghouse 926, 928
White Westinghouse 614, 101, 605
Yamaha 601, 617
Zenith 700, 614, 611, 900, 619
Feb 25, 2013 | Universal Remote Control Remote Control
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
Jan 10, 2013 | Avaya Partner ACS 308EC (108463001)...
Need a kenwood kvt-617 brain.
Hi someone stole the head unit out of my car but left behind the brain and wiring.
Apr 17, 2009 | Kenwood KVT-617DVD Car DVD Player
Kvt 617 default security codes please!
CALL DTR TECH IN DENVER. ONLY WAY TO FIX. 3035736288. WILL NEED TO SEND IN.
Mar 21, 2008 | Audio Players & Recorders
Kenwood kvt 617 dvd
Buy the same unit new in box then ask for code to see what they say. Then return the new unit keep the code. Because this time the new unit would have a serial number and receipt, they would just give you the code over the set and won't make you send it in and it still under warranty so the would be no extra charge. Just an idea though. Goodluck. Let me know if it work.
Jan 23, 2008 | Kenwood KVT-617DVD Car DVD Player
Lands Phones Logo
541 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
