Question about Brother IntelliFAX 4100 Laser Fax
Cleaning message We are not receiving any faxes and the message says to clean drum and clean corona wire of drum unit.
  • Anonymous Jun 06, 2008
    MY
    FAX MACHINE BROTHER MFC -8440 MESSAGE SHOWN CLEAN DRUM
  • canute983 Nov 19, 2008
    My brother 7010 has been coming up with dust on drum, clean corona wire. I've followed teh instructions and move the blue clip up and down and still teh problems persists. I cannot print or copy.
    Any ideas would be welcomed? [email protected]
    Thank you
  • 82 Answers
The drum unit may have a full waste toner hopper, I am not sure but defintely do not clean, or touch the drum, you may touch the the drum unit which has a corona wire which occasionally may need cleaning by running a wand across it. there should be a colored clip that will slide back and forth on the drum catridge to clean it.sorry i couldn't be more helpful without actually seeing it.
Thank You,
Mikey
Posted on Apr 04, 2008
This linke helped me . . . . a lot . . .
http://www.futuregraphicsllc.com/lit/tg/brother_1240_drum.pdf
Posted on Apr 03, 2009
2 Suggested Answers
SOURCE:
FixinFax
  • 3085 Answers
SOURCE: fax message says dust on the drum - clean the corona wire
You should find a BLUE SLIDER on top of the Drum Unit, work it back and forth 10 times.
Posted on Feb 02, 2010
Getting the message clean drum. Clean corona wire of drum unit. Need instructions on how to clean unit. What parts to I need?
You do not need any parts, just do the following.
1. open the front toner cover
2. take out toner and drum together
3. on the back side of drum unit you will see green or purple slider (it is used to clean corona wire)
4. push that slider few times from left to the right.
Important notice: you must leave slider on exact position to match black arrow on the drum unit.
BR
Sep 12, 2011 | Brother IntelliFAX 4100 Laser Fax
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
The fax machine is saying remove the drum there is dust on the corona wire.
Use the corona cleaning wire to clean the dust off. Open the front cover. Remove the drum/toner unit. look on the right side of the drum portion above the toner unit for a plastic tab with a triangle arrow that points to the left. Slide this tab back and forth several times. Move the tab back to the right. Reinstall the drum/toner unit. Close the front cover.
Clean the corona wire in this manner every time you change the toner/drum.
May 21, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax message says dust on the drum - clean the corona wire
Feb 02, 2010 | Brother IntelliFax-2820 Laser Fax
Dust on the drum message - fax 2820 brother
There is a blue colored slider on the drum unit, move it side-to-side 10 times.
Oct 05, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine has a message that says "open front cover to remove the drum. Clean the corona wire located on the drum."
The fax machine instruction must be done to erase the
message. The corona wire located on the drum needs to be cleaned.
Sep 24, 2009 | Brother IntelliFax-2820 Laser Fax
There is a line coming through when we receive faxes.
Try removing drum unit, and cleaning corona wire with blue "slider" if that doesn't work, replace drum unit.
Apr 29, 2009 | Office Equipment & Supplies
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
580 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
