Question about GPX MW3837 MP3 Player
Music wont play or show just keep saying mtp
Squared turquis color model mw3837blu usb ready don 't need battery just charge by computer
  • 8,596 Answers
Uninstall MTP device in device manager and press the M button on the side of this player
Posted on Jun 20, 2008
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
My Sansa e260 player works fine, plays my music and everything, but I have a problem with adding/deleting music. When I connected it to my computer, it did not recognize the player and it did not show up...
MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion..... make sure your usb 2.0 driver is installed..Syncing to wmplayer puts music in the mtp music folder. change usb modes again and use the explorer to see the sansa msc lets you sync any Q/A IM or email me @ Schmead01@yahoo.com
Jun 23, 2010 | SanDisk Sansa e260 MP3 Player
I need help on my Sansa e250, if I plug it to a computer or if i charge and even just merely turning it on, it just turn's on and off, my cousin who gave me my sansa told me that the battery was just...
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery and put the back on.
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music2_bing.gif folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installedMSC is best reate a music1 folder and put music in there then there is no switching back and forth to mtp msc
Apr 06, 2010 | SanDisk Sansa e250 MP3 Player
On my mp3 i had washed it on accident but the battery was dead when i did i tried to plug it into the computer it did nothing; i dried it it finally worked with my computer reading it and all; i instantly...
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager 1. Right-click My Computer, and select -- > Manage.
Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
*** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <--
Copy this address into a new window.
The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 23, 2010 | SanDisk Sansa E280 MP3 Player
I can't add music to my device.
the usb port encountered a problem with your device and will not recognize it, restart your computer and try plugging it into a different usb port on your CPU.
Jul 08, 2009 | Audio Players & Recorders
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
GPX MP3 Player Model # MQ3837
You will need to format your player. Doing this will completely erase any memory on your player. Follow the steps below:
1. Plug the player up to the computer using the USB cable.
2. Double click the My Computer icon on your desktop.
3. When that opens find your player under Removable Devices or Audio Devices. Some computers will show your player twice but will have the SD MMC card showing behind the player name. That is only for formatting the SD card.
4. Right click once on the player to open the Options menu and then click on Format
5. Click OK to any warnings that come up. There may be one or two depending on your operating system.
6. Any memory will now be erased from your player and you can disconnect from the computer.
7. Reboot your computer and plug your player back in.
8. When you see USB appear on your players screen, press and hold the M button until MTP appears on your screen.
9. Reload your music.
-Tha Mp3 Doctor
Nov 07, 2008 | GPX MW3836 MP3 Player
Only displays mtp and won't download songs
Try this out my player did the same thing plug your player into your computer using your USB cord and for like 10min let it charge there is a small battery inside the player after 10min hold down the M button for 5sec let off then take out battery plug back into computer it should say usb and now your set
Apr 18, 2008 | GPX MW3836 MP3 Player
MY GPX MP3 PLAYER MW3837 WONT SWITCH BACK!!...
keep it pluged in the usb to the computer then hold the m button down for six seconds then it will switch over to usb
Feb 26, 2008 | GPX MW3836 MP3 Player
Sansa c250 MP3 player
You don't need one, just go to settings, go down to "usb" mode, and if it says "playsforsure" and "rhapsody", pick "rhapsody" if it says "MTP" or "MSC" pick "MTP". Then, connect it to your computer. Go to your "my computer" folder, double click on the sansa. Then go to "tools" on your toolbar, click on "folder options", then click on the "view" tab, then go down to where it says "hidden files and folders", and check off "show hidden files". Click Apply, then OK. You should now see a translucent folder that says "music". Feel free to drag and drop any MP3 formatted music onto your computer. Please keep in mind that I've only verified this working on windows XP SP2, and that if it's not one mode, then it's the other, I know that Rhapsody is the mode you want to be in, but not so sure if it's MSC or MTP mode, try one, then switch it if it doesn't work Good Luck EE
Aug 11, 2007 | SanDisk Sansa e250 MP3 Player
55 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
