How to recover corrupted memory card
First of all, you should stop saving any new files to your Nokia N70 ( or memory card) or taking new pictures. Then find some photo recovery software from the following websites, which are able to recover deleted or formatted photos and movies from cell phone, digital camera, memory card and SD card etc. It also recovers photos from corrupted memory card. Digital Photo Recovery for Windows Digital Photo Recovery for Mac OS X Here are the steps: Step 1: Download and install the Digital Photo Recovery Software. Step 2: Connect your corrupted memory card to your PC or Mac. Step 3: Scan the source drive where your lost pictures located. Step 4: Recover the lost pictures and save them to another drive instead of the source drive. Best regards!
There are many ways that may lead to card corruption. And there are two kind of corruption: logical corruption and physical corruption. Physical corruption is unable to be recovered, and logical corruption can be fixed. But you should recover the files insides.
Here are some programs you may rely on to recover the files(photos, videos and music) from the corrupted card.
Photo Video Recovery Software (for Windows)
Mac Photo Video Recovery Software (for Mac OS X)
Have you tried this memory card on your computer?
If this memory card can be read functionally on your computer, you'd better copy off all your stored data to another memory card or drive and format this card immediately to check whether it can still be read on your phone.
But, if this card unfortunately also gets some errors on your computer, you'd better try to apply a memory card data recovery freeware to get all your stored data back successfully for free:
http://www.4cardrecovery.com/
In fact, this freeware helped a lot as the external hard drive of my friend was mistakenly formatted. It finally restored all the needed data of my friend. It always works well on both of a memory card and a hard drive. So, I believe it will also help you a lot.
Try to read more information of this freeware here:
http://micro-sd-card-recover.blogspot.com/2013/11/recover-photos-from-Micro-sd-card.html
After experiencing these troubles, I hope you can learn a valuable lesson to back up everything important well all the time.
Is this memory card still recognized by
your computer?
If so, you could plunge it back to your
computer via a card Reader and then download a corrupted memory card data recovery freeware to get back your saved data:
http://blog4mark.blogspot.com/2013/01/memory-card-recovery.html
The corrupted drive always could be damaged
logically or mechanically.
The logically damaged card still can be
fixed by reformatting and the contained data also could be saved with the help
of data recovery software.
But, the mechanically damaged drive is often
irreparable and the inner data is also irrecoverable.
So, if the data recovery freeware doesn't make
a sense, you'd better ask an expert for help, if the inner data is very, very important.
Do not worry you can recover files from corrupted memory card by using memory card recovery tool. When my SDHC card is corrupted, I was able to recover corrupted SDHC card files by using this tool. I hope this tool will help you to restore lost SD card files. You can get the trial version from the website to make a try and preview the recovered files.
SOURCE: Nokia N70 music edition memory card got corrupted
Ok, sorry for the confusion. I'll elaborate it this way. I have a Nokia N70 music edition phone bought in May, 2008. Till now it was working fine but 2 days ago, all the data from memory card got deleted. When I tried to access the card, it said "Memory card corrupted". I tried to format it but it doesn't work. I even connected it to PC but PC doesn't recognise the card. Hope this is clear. Please help!!
Thanks
suresh
SOURCE: My Nokia N70 Memory Card Corrupted, Can I repair
First, reformat your phone. Go to SETTINGS-Phone-General-Orig.phone settings. then type: 12345.
Be sure to remove your memory card, before doing it. And then, using a card reader, format your MMC on your computer. Right click the Memory Card Drive on MY COMPUTER, then look for Format. Click it and be sure to choose "FAT". Do not quick format. After that proceed. Put back the MMC to your phone, and check if it's ok. It worked for me so as i type.
SOURCE: How to recover datas from corrupted N72 memory card
You may try this mobile phone recovery software named asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
