I can hear 2 different channels on my plasma1 any solutions to fix this
    Problem Solver:
  • 44 Answers
I'd refer to the book that came with it and call tech support, but before you do that try searching the rear of the TV or a screw or a dial that you adjust for channels
hope this helps
Posted on Apr 01, 2008
TV Problem: No Video but Audio works
Here are some basic treatment for a dark display.
  1. On LCD TV, Some time missing or lose LCD strip from PCB connector. Solution- Clean strip and connector.
  2. Some time missing LAMP, burning lamp is a major cause for dark display in LCD TV. If lamp problem with any display, Display show in sun lights. Solution- Check Lamp connection/connector. Clean connector or change Lamp.
  3. In CRT TV, Fly back is faulted. There are no high voltages. Solution- Change or check fly back, Check out put transistor.
  4. Some OLED Tv Use OLED lights for display shining and brightness. IF LED's or lamps are faulted there is no display in sun shine.
  5. Before starting Troubleshoot display problem you need to conform and trace faulted stage of TV.
  6. Don't Apply any miss use trick at home. Contact the professional repairing lab.
  7. If you are full fault to understand your TV problem. Tip more condition of your problem.
Jul 02, 2015 | Element Televison & Video
My tv hear different channels but no picture
it must be broken back light. If You have a warranty which is still valid,
call service, if not better solution is buying a new TV.
Jul 20, 2014 | Westinghouse Televison & Video
I have a uniden uh038sx-2 handset and even though both units at set to same channels and all the planets are aligned, neither of them will send or receive. When you use one it goes int TX mode and th
First thing there are two settings that must be exactly the same or they won't talk to each other. 1st: Channel. You stated above that the channels are the same so lets move on to # 2: Different manufacturers call it different names but what you are looking for is the "privacy code" or "PL". If these are different on the two radios they will never (by theory) talk to each other.
A different "privacy code" allows your family to be close to my family using the same frequency without interfering with each other. In plan english, I won't hear you and you won't hear me because the "privacy code" is different even though the frequency (channel) is the same.
Jun 04, 2014 | Radio Communications
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Can't program cable channels
Hello there, the process for programming cable channels differ from unit to unit. Please provide the specific details of the unit system you own and the exact description of the problem to enable us give more precise and concise solutions to your problem.
Hoping to hear from you soon.
Thank you for visiting FixYa.
Sep 04, 2011 | Toshiba MW14F51 TV
My phone nokia 6700 classis has a hearin problems where the other person can't hear me...i need a solution for it pls
This is not a hardware problem! You're phone has grabbed a oneway voice channel. Report it to your service provider. They probably hv a bad t1 in traffic. (a t1 provides 24 different voice channels for conversations) It's quite possible you keep hitting the same t1 but a different channel.
Mar 09, 2011 | Cell Phones
I have 4 radios. Initially they all worked together. Now , een on the ame frequency , they do not all pick up the signal? Any ideas why?
These are FRS/GMRS radios. You may have different privacy codes set on the radios. If a receiving radio has a different privacy code than a transmitting radio, you will not hear the transmission. This allows many people to share the 22 channels, but only hear transmission from their party.
Nov 11, 2010 | Cobra 22 CHANNEL 2-WAY RADIOS
Blown sub, butIdon't know why
if you use a right channel on one coil and a left on the other different frequencies are going in different directions in each channel thus blowing a coil or badly damaging it-z
Feb 20, 2009 | Infinity Reference 1052W Subwoofer - 10"...
Same station same code only working one way motorola 250
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Aug 14, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Front right and left speakers problems
This is going to have to be a solution in the works...so don't rate until we have some kind of end-result.
Connect the speakers to a different device such as an MP3 player or a Nintendo DS. See if the speakers still cease to work. If they work just fine with a different device, then consider that it may not be the speakers...but a problem with the sound system in your PC.
Perhaps the sound configuration in Windows is disrupted. Perhaps the driver settings for your soundcard in your PC are corrupted. (A complete reinstallation of Windows with a fresh installation of the sound drivers would probably prove this theory right or wrong.)
Perhaps there is a problem with the FRONT CHANNEL hole on the sound system on the rear of your PC. You could check that by plugging the REAR channel of the speakers into the FRONT channel on the PC.
And lastly...there could be a break or a short in the cable of the speakers. You could always test another set of speakers with each sound channel and see if that might be the possible issue.
If the sound card in the PC turns out to be the problem, then install a different sound card. If the soundcard in your PC is currently the onboard one, then disable it in the BIOS before installing the new card.
Let us hear the results before we do any rating. Unless of course you're able to fix it with the data given. :)
Cyryl
Dec 08, 2007 | Dell 5650 Computer Speakers
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
