Question about Navman PiN 570 GPS Receiver
Replacing battery in a Navman 570
How do you diassembly this unit. I found only two screws under the flag but there should be two more??
  • 28 Answers
The 2 screws and then its hookeby plastic clips be careful cause clips break easy
you need a very fine flatblade screwdriver
richard from chicago
Posted on Apr 05, 2008
In addition to the 2 case screws under the GPS there are also 2 at the bottom of the unit which are hidden under flat round plastic covers. When all 4 screws are removed the case is still held by 8 internal clips one at each of the top corners, 2 on each side and 2 on the bottom edge. These can be release by pressing a fingernail into the gap between the top and bottom parts - note it is the top which must be pressed in to release the clips - start with the sides near the bottom of the screen. Once inside there are 4 screw holding the board in - 2 at the top corners, one at bottom right and 1 on the left side (under the gold cable to the screen). FInally the white connector at the top left must be disconnected (the GPS connection) and the the board together with screen can be removed by gently prising the board from the case.
Not difficult - but delicate and could be fragile.
Posted on Apr 19, 2008
Won't Charge
You need to change the battery. It is not a fun thing to do. Do a word search for Navman PIn 570 Replacement battery either on Google or Ebay. You have to disassemble the unit to get to the battery that is taped to the unit's motherboard. There are hidden screws on the back of the unit, then you have to gently pry the 2 halves off. Big Heads up here: the round dial on the left side...be sure to tape that in place when you first disassemble the unit, otherwise it falls out into 2 or three pieces...that dial is a pain to get back together if you do not tape it.
I recently replaced the battery on my unit. There are two additional screws on the back of the unit, near the bottom in addition 2 screws under the flip up antenna. They are covered by small black plastic discs which need to be pried off first. After removing the rear cover with a knife edge (or similar) there are several other screws which attach the circuit board to the front of the unit which need to be removed. Note that the one near the edge should only be loosened, and the board slid out sideways. Once this has been done you should be able to access the battery which needs to be pried off the board, as it is attached with an adhesive patch.
(If the battery is totally dead it takes about a day before the charge led starts flashing.)
May 20, 2009 | Navman PiN 570 GPS Receiver
Pocket pc navman 1022 charger and charger jack pin
sir, i have pocket pc 1022 navman pin 570 is not connecting with my pc.
May 16, 2009 | Navman PiN 570 GPS Receiver
Naveman PIN 570 gps receiver problem
i get the "waiting for gps" message if the gps unit is sending data to the main unit, but no satellite signal is found.
does the unit have sky view?
Sep 16, 2008 | Navman PiN 570 GPS Receiver
Info on fitting a new battery to Navman PiN570
Remove SD card and place the Navman on a soft surface face down so that you do not scratch the LCD screen. - Take out 4 screws ONLY. 2 under the gps antenna and two hidden black discs at either side of the bottom on back of unit,Make sure you use a small Philips screwdriver.
- Use your finger nail very carefully around the edges, go extremely slow to detach the cover. Once it opens, make sure of the Power switch button, they seem to fall off.
- Remove clear tapes at the battery connector. DO NOT pull up the connector, you need to pull sideways and make sure do not use excessive pressure while pulling.
- Place the new battery in same manner and also place battery cables neatly so that the do not come in the way while closing the cover. The LCD display should turn on. If it does not, look at the Battery connector and make sure it is all the way in.
- Put the cover back slowly and then make sure nothing is dangling along the edges. Do not forget to check the Power Switch button; it should be in proper place. Press the cover firmly, it should snap in place.
- Charge the battery fully before using Navman.
- Insert SD card. You may need to reload Navman application software or restore from SD card, if you stored on the SD card previously.
May 16, 2008 | Navman PiN 570 GPS Receiver
Pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
Mar 30, 2008 | Navman PiN 570 GPS Receiver
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Jan 23, 2008 | Navman PiN 570 GPS Receiver
Navman Pin570 battery replacement
There are 2 little black tabs at the botton of the back that you have to remove, behind these there are 2 screws u remove, and flip the ariel up and there are 2 screws under there you remove also.
The body is clicked together use a guitar pick, ur fingernails or small scewdriver to seperate the 2 sections.
Inside you will see a few screws holding the systemboard down, if need unscrew them.
you will see the battery its stuck onto the system board... be carefull seperating it,.. use a flat intrument or a butter knife to work it of the board ( its stuck on with double-sided tape or some kind of silicon)..
unplug it,
plug your new battery in.. BONGO
Let me know how you go.
cheers
plato
Put it all back together again
Jan 22, 2008 | Navman PiN 570 GPS Receiver
Cant get the menu display on my pin 570
maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
Dec 03, 2007 | Navman PiN 570 GPS Receiver
Navman 570
LET UNIT POWER 100 PERCENT DOWN AND PULL BATTERY THEN MASTER RESET
THEN PLUG IN USB CORD AND SEE IF IT WILL LET YOU REINSTALL WITH OUT BATTERY IN IT
THAT HOW I JUST FIXED MINE 4 MONTHS AGO
Oct 10, 2007 | Navman PiN 570 GPS Receiver
Navman PiN 570 GPS Receiver Logo
263 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
