Question about Garmin iQue 3600 GPS Receiver
Updater icon to whom it may concern, I brought up the Updater icon on my iQue PDA screen and the pop up menu come up asking if I want to reset the PDA Blah blah.with a yes and no choice. Instead of tapping the "no" I accidentally tapped the home icon and my screen went blank. I tried to reset and hard reset but no result. Also the power indicator light up and will not go out. Help... Trouble iQue
  • 4 more comments
  • Trouble ique Apr 01, 2008
    Can you get the firmware side so I can download it. Can you fill me in on the DKU cable. How is the DKU cable fit in my garmin PDA
    The hot sync does not do anything with my PDA.
    However my daughter she had one PDA and i tried the hot sync last Sunday and it works fine with my computer.
    I don't have the tool with me but I will try to remove the battery and plug in the charger when I get home tonite and will inform you tomorrow if it is okay with you.
    One more question
    Is the cradle considered a DKU cable? The dKU cable is nothing but USB cable correct?
    I am in Florence Kentucky. Do you know a place that I can bring my PDA to flash the chip?
    Will talk again tomorrow. Have a nice day..
  • Trouble ique Apr 03, 2008
    I did follow your instruction by removing the battery and plug in to see if it works. It does not do anything. And now everytime I boot up my laptop and the COM1 is not available for the Hot Sync Manager warning pop up.
    Any other idea...
  • 983 Answers
The firmware might have got corrupted due to that accident ...
you must take your cell to technician and get installed with new firmware ...
you can only try to install the firmware if you have the special DKU series cable which is compatible with your handset ...
as you have mentioned here in problem that you tried hard reset ...
i hope you did that using the DKU series cable ..
if this is right reply me i will give you the link to the firmware website ..... download and then try it...
note: but it is dangerous to try yourself because if you fail to install the firmware with any reason then your handset is just dead .... there is no way to get it out ... so be careful ...
handle with care ..
so it is better to contact the technician ...
Posted on Apr 01, 2008
  • 12 more comments
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Apr 01, 2008
    and one more thing just try connecting to the pc once if it is detecting or not ...
    if it is detecting means you can update your firmware very easily & there will be other options too just like reset etc....
    any way give me a reply ....
    i will try to get links but i am not sure i will get it or not ...
    there will be the DKU series cable which will be compatible for certain number of handsets ...
    The technicians will use this only to reset,master reset , for flashing etc...
    when you purchase the suitable DKU series cable they will provide a manufacturer cd which contains the software with the options to reset,flash etc ...
    just have a search if your PDA handset doesnt have any DKU series cable means then you must and should take it to the technician ....
    the technician will short circuit the microprocessor by this everything in the RAM chip will get erased including firmware then after this they will install the new firmware ...
    i am sure the DKU series cable will be available for your handsets ....
    you try connecting to pc once check whether handset is detecting or not ...
    try removing the battery & plug in the charger with out battery ...
    alright ....
    but i think it s better if you try connecting to pc too so that you may be able to know the status ....
    after trying that it is better to contact technician because you already invested much on your handset if you try yourself to install the os if any reason you fail then your handset is of no use ...
    even any technician cannot make it right ....
    if this instance happens there is only one way you must give it to the company and change the whole chip ...
    so it is better without losing your handset you just contact technician ...
    but also if you want to make it right by yourself then reply me ...
    i am always here to assist with it ....
    the cable what we used to connect is called as USB data cable ...
    DKU cable is the tool kit used by the technicians to solve the problem like
    for instance if you would have forgot some passwords, security codes etc they will use that to reset the codes into default codes .....
    but we can install the firmware by using USB cable too for some handsets like yours for that thing the previous firmware must be working or there must be connectivity with the pc ...
    for better understanding read this :
    in all mobiles there will be one chip which stores some manufacturer information or which is responsible to obtain the connectivity with the pc so in your handset if your chip has that information then there will be connectivity with the pc ..
    i dont have the idea about the cradle ...
    but there will be some paid softwares which allows the installing of the firmwares by using the same usb data cable too which are used by technicians ...
    for that as i previously told your handset must show connectivity with the pc...
    sorry i dont have idea about your place ... i am from bangalore,india ...
    but i can give you some tips where you must go ..
    you go to the exclusive showroom where the service will be provided .....
    ya fine ... same to you ...
    bye ...
    thank you & bye ...
    Dileep Keshavanarayana Apr 09, 2008
    hello...
    sorry for late reply..
    i was out of station ...
    ya the last and good idea is to visit the service showroom and to get installed with the new firmware for your cell as i have mentioned in the earlier posts...
    The reason is also mentioned in the earlier posts....
    thank you
    Sergeant:
  • 406 Answers
Please update the firmware or software from internet or its cd.
I am online ur feedback is highly appreceiated
SOURCE:
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Instructions
Complete Reset
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
Player is froze
Release it, then turn it on again. Go to the Sansa website (http://www.sansa.com) and download the "SansaFirmware Updater." Select "Run" when the updater installs.(Installation will take less than two minutes.) Wait for the Sansa Firmware Updater to run through its system test. It willask you to connect the Sansa Clip to the computer to update your Sansa'ssoftware. Connect the Sansa Clip. Remove it from the computer when instructed. If thisprocess does not unfreeze your Sansa Clip, contact Sansa support at the SansaFirmware Updater website.
Complete Reset
Turn player on. Press the "Menu" (home) button.
Pressthe bottom of the scroll wheel until you reach the "Settings" screen.Push the center button to choose "Settings." Scrolldown to "Reset All" and select. You'll be asked to confirm the reset.Select "Yes." This option will simply allow you to reset the languageand location settings on your Sansa Clip. Thiswill not erase data from the clip.
To doa complete factory restore, whichwill erase all files from the clip, follow these steps: Inthe "Settings" menu, scroll down until you reach "Format"and then select. You will be asked to confirm that you wish to format. Select"Yes." Wait for the screen to say "Formatting Complete."You have now cleared all the files from your Sansa Clip and reset it to factorysettings.
Oct 24, 2010 | SanDisk Sansa Clip MP3 Player
It says i have no connection between my handheld and my computer when i try to hot sync
If you are trying to HotSync to a Macintosh, you need to install Lycestra's PDiQue software available at http://www.lycestra.com/ique.html before HotSyncing is enabled. PDiQue enables a USB conduit between your Mac and the Garmin iQue 3600.
Oct 23, 2009 | Garmin iQue 3600 GPS Receiver
I left my Sansa Clip MP3 Player plugged in while putting my laptop into hibernation. Now player does not response, I can't turn it on, and laptop doesn't recognize it at all.
    Complete Reset of Sansa Clip
  1. Step 1 Turn Sansa Clip on. Press the "Menu" (Home) button on the Sansa Clip.
  2. Step 2 Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
  3. Step 3 Scroll down to "Reset All," and select. You will be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow steps 4 and 5.
  4. Step 4 In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm if you wish to format. Select "Yes."
  5. Step 5 Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
  6. Resetting a Frozen Sansa Clip
  7. Step 1 Unfreeze a frozen Sansa Clip by pushing the power button up and holding it for 20 seconds. Release it, and then turn it on again.
  8. Step 2 Go to the Sansa website and download the "Sansa Firmware Updater."
  9. Step 3 Select "Run" when the updater installs. (Installation will take less than two minutes.)
  10. Step 4 Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
  11. Step 5 Connect the Sansa Clip and then remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Aug 22, 2009 | SanDisk Sansa Clip MP3 Player
IQue 3600 power connector specification needed
see "http://pinouts.ru/PDA/palm_m125_pinout.shtml
Apr 27, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset...
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Dec 20, 2008 | Garmin iQue 3600 GPS Receiver
Screen replacement for GarminiQue 3600
I have a 3600 that worked perfectly until i hit the "UPDATER" icon at Garmins suggestion, it fried something but the screen and the rest of the unit are in great shape........ I could not shut the unit off so I took the batter out, the screen is fine, if anyone want it for 40 bucks, drop me a line......... [email protected]
Nov 04, 2008 | Garmin iQue 3600 GPS Receiver
Cant get it to work
If this is an IQue 3600 then you will need to install the Palm Desktop from your original IQue disk in order to sync with your new laptop. The Microsoft active-sync is for a PDA using Windows (Garmin M3 and M5 are windows based PDA w/GPS).
May 09, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
