Question about Intel D845GBV (BOXD845GBVL) Motherboard
Intel D845GBV Motherboard RAM
I am Guru here
I am using Intel D845GBV Motherboard Problem, 256MB DDR RAM with 266Mhz currently.
Now I want to upgrade my RAM 1 or 2GB, Should I need to get 2GB RAM DDR with 266Mhz or can I use 333Mhz or 400Mhz ?
And Is 2GB DDR RAM with 266Mhz is available ?
  • 655 Answers
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Posted on Apr 01, 2008
I have a Hp Pavilion 733b with chipset 845g, i have 1gb of ram but just recognise 256mb
Product: HP Pavilion 733b Desktop PC
Motherboard: FIC VG31
[ First International Computers ]
Motherboard specifications;
Memory Type: DDR Sdram
Memory Speed: DDR Sdram at 266MegaHertz, or 200MHz
(PC2100, and PC1600, respectively)
Memory Sockets: Two. For Dual Inline Memory Module/s.
Maximum Memory: -> Maximum TOTAL Amount for motherboard.
Maximum Amount for EACH ram memory slot: 1GB
So far looks good, BUT;
1) Is the Ram Memory Non-ECC?
2) Un-Buffered? (Un-Registered)
3) Voltage: Does it use 2.5 Volts?
JEDEC standard for DDR Sdram ram memory voltage is 2.5 Volts (DC)
FIC is going to set the ram memory default voltage at 2.5 Volts.
Point? DDR Sdram at 2.6 Volts, or higher, may not work.
Betting the motherboard doesn't have SPD, and the ram memory may not either.
4) Ram Memory frequency rate:
What frequency rate of ram memory are you using?
(Excuse me,...'Speed')
The Intel 82845G Northbridge chip, will only support DDR Sdram at a -> Maximum <- frequency rate, of 266Megahertz. (266MHz),
I have seen websites offering DDR Sdram at 400MHz for this board.
Maybe there is a BIOS update, I don't know. But going with the standard BIOS program that is installed, and info for the Intel 845G support, I would say this = No.
Processor Front Side Bus (FSB) support is either 400MHz, or 533MHz.
Ram memory typically operates at HALF of the Processor's FSB.
That would be 200MHz (PC1600), or 266MHz (PC2100), respectively.
[Half of 533 = 266.5
It's just rounded down to 266 ]
Can you read a manufacturer's label on the ram memory modules?
If so post what you see in a Comment.
[Sometimes when upgrading ram memory, it may take you to turn the computer completely off, and wait 1 minute. Then turn it on, and let it run for a couple of minutes, then turn it off. Wait 1 minute, turn it back on.
IF, the motherboard does have SPD, and IF, the Ram Memory has SPD, it may take a couple of 'Cold Boots', for BIOS to recognize the Ram Memory.
Some of the old mobo's were just like that.
{MOtherBOard ]
Jul 11, 2012 | Computers & Internet
I have 266 mhz 256MB RAM with intel D845 board. I want to upgrade it to 512mb or 1GB. Can you please tell me whether 333/400mhz will be suitable or where can I get it in hyderabad
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link
Aug 18, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
Restarting computer frequently
yeah it is the generic problem of d845gbv, for boot setting change the motherboard battery.
Nov 08, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Upgrade my RAM
This mother board don't support 400mhz , so if you want to upgrade the RAM better just get another 266mhz...
Check this link for the info
Hope that helps.....
Jul 11, 2008 | EliteGroup P4VMM2 Motherboard
PC1600 runs at 200MHZ and PC2100 runs at 266MHZ..
Since your motherboard only supports a max of 266MHZ, I would recommend that. (not to mention that PC1600 is pretty much obsolete)..
2nd, you motherboard supports a MAX of 2GB Total ram.. So, you could install 1GB + 256MB.. But why not go for 2xGB?
The price for a 1GB stick of PC2100 is around $75-125 CAN. Not soo cheap anymore...
Apr 02, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Can i use DDR2 RAM in intel 865GBF motherboard?
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Mar 30, 2008 | Intel D865GBF Motherboard
Open Questions:
Intel D845GBV (BOXD845GBVL) Motherboard Logo
228 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
