I have a DVP3340V/17 VCR&DVD player. No matter what connections I try, I cannot get the Set/Menu to appear on the TV screen. My TV is a Toshiba 37" REGZA LCD TV.
  • hoop5087 Apr 01, 2008
    Nothing is outputted from the DVD to my TV. I've tried all the various connection listed in the DVD/VCR without ant success.
  • hoop5087 Apr 02, 2008
    I have not had any response to my last comment advising you that my DVD/VCR appears to be operating in responding to my remote controls. Even though my DVD shows Setup on its panel, no setup appears on my TV screen.
  • 1,944 Answers
Can you get anything outputted from the DVD player to your TV?
Posted on Apr 01, 2008
  • Damen Wong
    Damen Wong Apr 01, 2008
    Does the DVD player appear to be operating normally?
  • Damen Wong
    Damen Wong Apr 03, 2008
    Sorry for the late reply. Is there any way you could try the player on another TV? Perhaps the problem is with the TV.
Does this machine have a coaxiel cable connection on the back for cable TV?
The DVP3340V does not have a tuner so it doesn't have a coax input. It is meant to be connected to a set top cable or satellite box for recording to the VCR and then to the TV or just connect it to the TV for watching a video.
For details, see the manuals and documentation here:
I hope this helps.
Jan 28, 2011 | Philips DVP3340V
What channel do I set my tv to to watgh a dvd
Mostlt likey 3 or 4.
Please explain how you have it connected so that I can be sure.
What input (connections on back of television) do you have it connected to on the television?
Or if you could explain the colors of your wires.
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Feb 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Well fbyrd95 goodluck. I have checked out the pages they offer for help. You will need to purchase a cable/satellite box to get the channels routed through the vcr. I received one of these for christmas. It is the sorriest excuse for a vcr/dvd combo I have ever seen. If this is bought as a dvd/vcr combo then I would assume that vcr means that it will record. I do not have the receipt or it would be returned. I will never purchase a philips product.
Jan 03, 2008 | Philips DVP3340V
I'm not sure if you've done this yet, but this might work.. goodluck to you... let me know if it helps
Dec 31, 2007 | Philips DVP3340V
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
