Question about Canon PIXMA MP530 All-In-One InkJet Printer
My fax is not recieving from an outside call,
I can fax to people. But I can't get my fax to ring or except a fax when it is being called in.
Posted on Apr 08, 2008
Our fax machine says recieve error and will not recieve faxes
I presume the machine has its own telephone line. Lift the handset and make a telephone call. Can they hear you ok? Can you hear them OK? If both ok then have them ring the fax and you answer it with the handset. Can they hear you ok? Can you hear them ok? or can you hear crackle on the line or any other strange high frequency noises? If you hear these noises then your telephone company will need to clean the line. Thats usually why this problem arises. the SF5100 was Samsungs best fax in my opionion. It did not suffer from any problems except wear and tear like all machines.
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Everything works fine except receiving a fax.
Check the answer mode, you should easily be able to see it in the display when in idle mode.
The CD is not needed for the machine to perform actions not requiring a computer, e.g. sending/recieving faxes.
Also, check the phone cable connection so that it's connected to the LINE outlet, and not the EXT one. Connecting it to the wrong contact would still make the machine ring (as it detects the "call" on the line) but unable to lift the call since the modem communicates only through the LINE port.
You could troubleshoot by letting the machine be alone on the line to see if it can send and/or recieve faxes.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a fax number shared with my telephone line. It malfunctions when recieving a telephone call - only sometimes and on only two numbers. When someone tries to make a telephone call to me from those...
It looks like you have a distinctive ring service from your phone company. Change the ring pattern of your fax to its assigned ring pattern (double or triple ring). It could be assigned to 'all rings' right now, that's why your fax is picking up your landline calls as well.
Mar 06, 2009 | HP Officejet 5510 All-In-One Thermal...
Fax recieving faxs
If you only use this line for a fax the least stressful option is a fax to email service and re-direct the incomming calls.
If you use this line for fax and phone do as I suggest above except re-directing the calls but dont forget to tell those who fax you of your new number
Jul 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
MaggieB
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
96 people viewed this question
old marine
old marine
