Question about Toshiba Office Equipment & Supplies
How do we set up proper ftp server connection to receive scanned images with our Toshiba 232. the current file path is \\\ but when we try to scan we get a FILE STORAGE ERROR. we have entered the correct server name and password. any suggestions.
The path is all \'s not /'s. needs a shared folder named scans and the copier needs a users valid login name / password for the computer sharing the scans\ directory.
Posted on Sep 18, 2008
Received this error while scanning: User cancelled operation Canon DR-9050C Driver Version 1.9.11303.26001 (-4526) File access error occured. Check write protect or disk full
Maybe the default folder that is set up to receive scanned images has been set as 'read only'.
This sub-folder will most likely be in your default user folder.
Look for something similar to 'Scans' 'Scanned' 'Scanned images'.
Right click folder name in Explorer to view / change properties. OR..
Your printer interface software should allow an option to change the save path.
Also check drive capacity in My Computer screen.
Nov 20, 2017 | Canon Office Equipment & Supplies
I am an IT pro who has an AR-M355U. We are having a problem with some new email addresses we entered. We changed the suffix of the address to a new service, and the decive stopped sending scans to our...
CE-O3 = The specified server suspends reponse during transmission of images.
Cause: Improper connection of the network cable, An error occurs in the SMTP server/FTP server/ NTS
Check: Check that the network cable is properly connected.
Check the SMTP Server/FTP server for any trouble.
Aug 23, 2010 | Sharp AR-M277 Black and White Copier
Canon 6570 Copier Scan to a network file share, not email it
the easiest way to do this is to goto additional functions, address book, register new address, file, then you can type in the name you would like ie. Bill or Contracts. when it asks for the file path change it from ftp to smb and then select browse this will let you browse the network and just select till you get to your shared file. you can also type the ip address in the address bar of internet explorer and manually put the file path in the RUI under address book.
Aug 31, 2009 | Canon IMAGERUNNER 6570 Copier
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Jun 10, 2009 | Sharp AR-275 Copier
Error code CE-02 when in the scan mode.
the FTP server cannot be found. This is a network error. If it is connected to a network, check with your IT person to set up the FTP server.
Apr 13, 2009 | Sharp AR-M455N Copier
Can't Transfer image to FTP site
"STOR" is FTP lingo for storing (putting/uploading) the file onto the server. I'm presuming you have entered the appropriate FTP IP address, login and password and the FTP server is setup properly.
Presuming the FTP server is set up correctly, connect your computer to the same cable the Sony IP camera is connected to and use an FTP client from your computer to confirm you can successfully upload files.
If you do not have an FTP client, you can download a free one at:
Dec 06, 2008 | Sony SNCRZ25N Network Camera Snc RZ25N
SMB settings error.
if i remember right, the settings should be:
server: / or server name
folder: Sbssvr1\Scans\SCANS
and if still not working, try give some user name and pwd, some networks require this.
Apr 24, 2008 | Konica Minolta bizhub C250 All-In-One...
Ricoh 2045
Go to your desktop. Create a folder named "scans" on the desktop, and share it. Give the "everyone" group full access, or give users permission to modify files. Depending in how its set up.
On the copier, since you already have Email setup, your dns servers will be entered. Go to:
user tools, system settings, admin tools, address book management. Either select a user, or new program. Fill in user name ect. Select folder. It will ask for a path. Enter the path using the following template"
\\computername\scans. You should be able to test it out. If it is successful, then it will prompt you to login. This is your local login for the computer with the scans folder, The password is its password. Press ok to save.
Select scanner, scan document to the user that you set up. If the memory goes from 100%, to 99%, to 100% quickly, it worked.
You can use variations of this on a server too. If its a domain server, assigned to a group, the user name and password are what the user uses to access the active directory.
Mar 28, 2008 | Ricoh Aficio 450 Copier
628 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
