Problem with Picture
The picture has does not fill the screen even when I try to adjust the picture it dosen't change on both side of the pictue it is concaved.
  • 149 Answers
Pin problem it wont adjust untill pin amp circuit is repaired
Posted on Apr 01, 2008
SOURCE:
My Tv screen dosen't fill the whole srceen
Just on a movie or even watching tv???? If you have the original remote, usually there is a ratio button on it you can push......If theres not, go into the menu and go under video and look for the different ratio (size) of the picture and try one of them......If you still can't figure it out and dont have your manual, you can always "google" your tv and model number and download or at least look at the manual online.....good luck....
Apr 13, 2012 | Televison & Video
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
White lines and blurry across top of pictue
On our Sharp LCD this happened when the picture format was changed. We have a stretch function which caused this issue. If you go into your TV menu you may have the same type of settings depending on your TV. It happened to us mostly during commercials when the signal changed. We simply adjusted the screen sizing and it went away.
Mar 02, 2011 | Televison & Video
I have a westinghouse LCD tv SK-32H635S. I used
Hi:
If you are using the television with a cable box try looking a format button the the cable boxs remote to change aspect of the pictue. Also try unpluging the unit from the AC outlet for at least two minutes to reset the unit.
Mar 14, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
I have a 56inch and picture looks like it's in 3d.
Is picture to Large or Does ot have 3 out of line colors? If to large Go to Zoom,pictue screen adjustment width length-custome,sports ect If 3 colors you have open fuse.
Aug 14, 2009 | RCA HD52W59 HDTV Projection Television
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Picture size
I called RCA about this and first was told that it was my cable company till I told the rep that it does this even when I unhook the cable. I was then told that I could take it in to get it fixed and that even it it was a bad part on their end that I could end up paying for it as if might be the pictue tube or the screen. Guess this will be the last RCA that I ever buy again.
Oct 22, 2007 | RCA F27450 27" TV
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
