Netgear wgr614 Router problems
I have installed everything properly and I have a wireless network but my laptop won't connect to it it has a message "The settings on this computer for the network do not match the requirments of the network. Can anyone tell me what I need to do to rectify this
  • geovril Apr 02, 2008
    Didn't work still have the same problem I am trying to connect the laptop wirelessly but you have mentioned reconnecting the laptop to the router can you tell me why.
    Geovril
    Sergeant:
    Champion:
  • 427 Answers
Yea this is simple;
1. disconnect your computer from the wireless network and turn off the wireless wi-fi, or take out the wireless card.
2. Restore the factory defaults on your router.
3. set up your router to your liking again.
4. Turn on your wireless inside your laptop and reconect to the router.
Posted on Apr 02, 2008
SOURCE:
Laptop can not connect to netgear wireless router
I would suggest using the network setup wizard, in the control panel. Best option is to copy the data to a pen drive and transfer to your daughters laptop.
May 30, 2010 | NetGear WGR614 Wireless Router
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
Laptop does not receive any signal from router.
You have not mentione the issue. You have just posted that everything is allright and working.
Sep 01, 2009 | NetGear WGR614 54Mbps Wireless Router...
I have tried everything to get netgear on to my laptop
Take a look at the information here
I developed it to fix a lot of minor home networking problems and there may be somthing of use to you there.
Aug 23, 2009 | NetGear WGR614 Router
Win xp network
Check the wireless switch of your laptop if "on" or not. Then try again to scan available wireless network
May 11, 2009 | NetGear WGR614 Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
Problems connecting my laptop to wireless router
Make sure that you do the setup via cable, not through wireless!
If you change form WPA to WEP, the length of the key changes and you will have to provide this new key if you want to connect wireless to your router.
You can leave your laptop connected via cable and check if your wireless card can connect.
No, you don't have to reinstall everything again. Just plug in the cable, connect to your router (192.168.x.x) and check your wireless setup.
Dec 28, 2008 | NetGear WGR614 Wireless Router
Wgr614 wireless router will not connect
This makes me think that the wireless in either the router or the laptop has failed. Will the laptop connect ok if at another hot spot? if so, then you may have a problem with the router. If the laptop will not connect when somewhere else, then the wireless in the laptop has a problem. that could be a problem with the internal wireless card, or a driver file corrupted. Check the wireless card through the device manager to see if windows reports it working properly, and make corrections there as may be necessary. If windows reports all is ok, you may need a new card.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 24, 2008 | NetGear WGR614 Wireless Router
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Problem
dear leetheone,
your network wireless is not properly set up. you have to properly set this, try using the windows wireless wizard and follow the prompts.
sid
Dec 02, 2007 | NetGear WGR614 Wireless Router
Open Questions:
Computers & Internet Logo
177 people viewed this question
Ekse
Alun Cox
