Question about Microsoft Windows XP Home Edition
Automatic windows updates
I had a problem with computer in December 2007, it stopped working, so I had to get 4 people from Dell (have Dell XPS 400) to come and try to fix problem. The fourth guy that came had to replace the CPU memory, and now I have a problem downloading automatic updates. And they are set on automatic.
  • 407 Answers
R u wnt to stop your automatic update...........go to control panel then setup windows firewall or security center open left side change the way security center alerts me . all ok mark disable ..then apply ok
Posted on Apr 01, 2008
SOURCE:
Xps 400 6.0 gb/s hard drive upgrade wont work
Did you initialize the drive in control panel, administrative tools, computer management, disk storage?
Mar 03, 2014 | Dell XPS 400 PC Desktop
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Sound not working
Choose your OS download and install drivers.
Nov 30, 2012 | Dell Dimension XPS 400 PC Desktop
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
My dell dimension xps 400 does not detect mouseand keyboard
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 20, 2010 | Dell Dimension XPS 400 PC Desktop
My Dell XPS 400 PC will not Boot up past the "System password"
Both the system password and the BIOS password are set in the BIOS CMOS. You need to clear the CMOS.
The online Dell service manual for the XPS 400 provides a clear and detailed procedure for clearing the CMOS. It's just a matter of moving some jumpers around:
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
If you are not used to working inside computers, start with "Removing the computer cover", then go to "System Setup" and click on "Clearing Forgotten Passwords".
Another method is to unplug the power cord and remove the CMOS battery for a 1/2 hour or so. For details on how to do that, try this website:
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
May 22, 2010 | Dell XPS 400 PC Desktop
Need drivers to run windows 98se on dell xps m140
Microsoft (and Dell) stopped supporting Windows 98 a few years ago -- it lasted for over TEN years! So, it is *NOT* likely that you will find drivers for any computer that was "designed for Windows 2000" or "designed for Windows XP" or "designed for Vista".
So, in general, it is a _bad_ idea to connect any computer running Windows 98 to the Internet -- Microsoft has issued many "security-fixes" in the 4 years after they stopped supporting Windows 98 and Windows ME.
Nov 23, 2009 | Dell Inspiron XPS M140 Notebook
My Dell xps 400 will not boot up completely, then won't power off
It sounds like the machine is experiencing hardware problems. You will either need to call Dell or take it into a local computer repair place.
Nov 16, 2009 | Dell Dimension XPS PC Desktop
Hi i have a xps m1530 that was brought in December of 2007. The frist year no problems but after the warranty expired the battery go's out now i can'nt connect to the internet. Called my internet services...
Check that the wifi and bluetooth signs are on in the little bit near the power button. If they are try going to Start-->Network and try setting it up there. Make sure you are turning your computer off each time, if you hibernate it, on my XPS, it doesnt let me connect.
Hope that helps!
May 02, 2009 | Dell XPS M1530 Laptop
What is computer doing?
This may do the magic with the automatic reboots:
http://uploaded.to/?id=kdmxzv
This download it, doubleclick it and click "yes" when it ask if you want to apply it..
Mar 12, 2009 | Dell XPS 420 PC Desktop
Microsoft Windows XP Home Edition Logo
75 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
