Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
51PW9303 I know i will be replacing the STK392-120 IC`s,But i was wondering what resistors i might be looking at replacing or caps that need it?
  • 138 Answers
By 7045 cap 2061 and resistor 3148 and 7044 should be the only thing.
Posted on Aug 19, 2008
  • Lawrence Smith Aug 19, 2008
    If that don't correct the convergence replace the board they sit on.
No picture. Sound is OK on Philips DPTV345 model 51PW9303/17F
I would check the solder on the Vertical output IC as ofetn the soolder will crack and the CRts will shut down to prevent damageing the CRts when vertical drops out. If the solder looks good I would try replaceing the vertical IC very inexpensive and you can get the vertical IC from www.tvrepairworld.com
Feb 10, 2013 | Televison & Video
The manual converge is all unaligned and I can't get it back together and now I can't watch tv without seeing all colors
need to repair the comvergence ic , and maybe replace 2 resistor , this repair is about $250 , i would recomend u to hire a tv tech for this job , because after they replace the ic they may has to do some aligments
Aug 26, 2010 | Philips 51PW9303 51" Rear Projection...
Convergence problem
There are 12 resistors all of them are 6.8 ohm 1watt resistors they are located in front of the ICs heat sinks at board location numbers 3149 -3160 they will all be identical and are grouped in sets of two side by side.
Jul 31, 2010 | Philips Magnavox 51MP392H Rear Projection...
Color won't converge
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Philips 51PW9303 51" Rear Projection...
Tv shows circular double lettering on the top and bottom of screen. what is wrong and how can i fix it
Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink2.gif compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks2.gif with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Oct 12, 2009 | Philips 51PW9303 51" Rear Projection...
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
Avm 3259 picture problem
Vcc is on Pin 6 of the vert. output IC so you can trace that back to it's feed resistor (not sure the location number but you can find it easily by following the circuit trace). Depending on what your problem is you may need to replace some electrolytic capacitors as well. Follow pin 7(pump up) back to it's electrolytic cap. and look for swelling or bulging. Look for other bulged capacitors in the vertical section. You may also identify a bad resistor by a discolored look but not always, if in doubt meter it.
Let me know if you need some more info.
Oct 03, 2008 | Sanyo AVM-3259S TV
Philips tv 102cm rear projection
You need to replace both convergence ICs they are STK392-120 and you will also need 4 of the 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Aug 01, 2008 | Philips 51PW9303 51" Rear Projection...
Partial horizontal collapse. Nu-tec Model NTT-829A
If you have retrace lines I would recheck all caps around the vertical IC 100@16 is the most common 47@35 and 220@35
May 30, 2008 | Televison & Video
Convergence Board
Have you tried just replacing the STKs? This set uses two STK392-120s I think.
Dan
Mar 18, 2008 | Philips 51PW9303 51" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
