The MIP480 Bluetooth interface does not have a Bluetooth PIN set as default, the Bluetooth stack on PC's and phones often require a PIN for pairing security. If you are being asked for an PIN you can set on in the printer using the Firmware Download Utility. The utility can be downloaded from; http://www.dascom.co.uk/Support/Default.aspx?type_id=7&info_id=5&itemid=24&name=MIP480&act=4
Try contacting your local dascom dealer, or contact dascom directly see www.dascom.com for more information. They will be able to advise on local spares reselers in you area.
please check that u select the proper printer before preceeding for print command. Also check that the printer connected to ur system is ur default printer.
