Question about Xerox Phaser 7700 Laser Printer
Print cartridge "missing"--NOT
Our Xerox 7700 is giving a message that the Number 4 print cartridge is missing.
The cartridge is not missing.
The message appeared after a staff member replaced print cartridge number 2.
Any suggestions for fixing this?
  • usayank May 05, 2008
    All of the sudden my xerox 7700 wont recognise print cartridge 3. It was replaced only one month ago and I have only used approx. 500 prints so far, I have done my best to check everything you mentioned, but still have same problem. If I swap print cartridge two with three, two recognises, but three still does not? Thanks for any help you can offer, Anson Bentley
    [email protected]
    Novelist:
  • 256 Answers
In order to solve such a problem in your printer cartridge, you should take a flat blade jewelers' screwdriver along with a blade whose width is somewhat more extensive compared to the pads and place the blade side flat throughout the contact.
After that, drag the blade end throughout the contacts, from each direction, knocking down firmly with the flat.
You may experience blows as you traverse the pads.
It is to compel the ridges in the region of the holes back to the holes.
This procedure has proved to be of great help for most of the users who have experienced the "Print Cartridge Missing" error.
Posted on Aug 03, 2011
    President:
  • 2,072 Answers
Problem:
Cause:
Solution: print cartridge Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Door A not closed properly. - Open and close door A, then power cycle the printer and check for the error again.
2. The rails that the print cartridges slide in are misaligned or bent. - Remove the Transfer belt and all print drums, then check and re-align print drum rail guide. Then reassemble and verify proper operation.
3. Interlock actuator tab for the front door is broken off. - Check the interlock actuators on the front door if misaligned or broken then replace the front door, if they can be reconstructed then repair. Otherwise call for additional parts.
4. Cable connection to the Engine control board is not seated properly or fully. - Check all cable harness and wires to the Engine control board and make sure proper connection is made.
TROUBLESHOOTING TIPS AND HINTS:
Check all media trays, access doors, and front cover for proper closure and interlocks being disabled.
Posted on Apr 01, 2008
  • Rick Kasper Apr 01, 2008
    5. One or more of the Print Drum Cartridges is defective. - The drum should be replaced with customer stock if it is determined to be defective.
SOURCE:
Xerox 7700 won't get past the startup screen
Make sure the image control board is not missing anything.
and maybe try replacing it with a diffrent image control board.
Goodluck!!!!
Feb 25, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700 color printer -color not decent
There are several user diagnostic routenes you can run to clear things up. Best thing I can recommend is to go to the Xerox.com site. Click on support and drivers,when the search box comes up type in 7700 and follow to support area. You can search specifics there. It is a good site.
Sep 09, 2008 | Xerox Phaser 8200 Laser Printer
Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Sep 07, 2008 | Xerox Phaser 7700 Laser Printer
Unit 11 laser polygon motor failure
Most likely, all the problems you are experiencing are being caused by a bad laser motor assembly. We can send you a motor assembly for the laser unit and you can change it out yourself, however, we will have to charge for the entire unit since it makes one laser unit worthless. You would save on shipping that way. Aligning the lasers is a little tricky, but doable. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Aug 12, 2008 | Xerox Phaser 7700 Laser Printer
Hi, I have the Xerox Phaser 7700GX. I have a scrolling message that says 'cartridge 1,2,3,4 is missing' and tray 4 is missing. I've tried troubleshooting through Xerox'x support site - where I've switched...
That really sounds like corrupted software
Go to Xerox.com
Click "support and drivers"
Enter "phaser 7700" then click the orange "search"
Then "drivers and downloads"
Scroll to "firmware update"
Download it and follow the instructions to load your printer software.
That should correct your problem.
Apr 30, 2008 | Office Equipment & Supplies
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 7700 gx getting false errors all ove the printer
It might be somthing with the side cover not sitting right. If you feel comfortable doing it, remove and reseat the right side cover. I had a similar problem and this fixed it.
May 29, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
590 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
