Question about Motorola Mobility W375 Cellular Phone
Camera Hello! I was going to to take a picture and when a pressed camera it came up with a blank, black screen and eventually it said fail. Is there a solution for it?
  • 983 Answers
Try giving restore factory settings.........
if problem persists then have a have whether the camera is working correctly not,....
before taking pic just check whether it is showing or not,,,
try to record video once ... if it cannot able to show means then the camera strip is gone so you get it changed..
visit the technician..................
Posted on Apr 01, 2008
Blank screen when taking a picture
Yes it is. Press the DISP button on the back of your camera. This manually turns the screen on and off to save batteries.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
My camera d580
First, make sure the batteries are fresh and installed correctly. Turn on the camera, if you get an opening screen, your camera should be OK. Press the menu button and navigate to screen options where you should be able to turn on the screen to take pictures.
If there is no opening screen when you turn on the camera (and you are sure the batteries are good and in properly), then try to take some pictures without the screen. If the camera takes good pictures, then the screen is dead. You can continu to take pictures with it in this condition. I do not think they are worth fixing, though.
If the camera does not take good pictures or no pictures then the camera has failed or dead. Your best solution is to replace the camera with a newer, better one, More pixels, greater optical zoom, quicker start time and so on.
May 31, 2009 | GE E1040 Digital Camera
When taking a picture, camera screen is black
It is problem of bad CCD imager IC and this part needs to be replaced.
Sony will repair it free of cost as per announced scheme for this problem in DSC-T1 Camera.
Please click on Sony CCD Support for details. If you are in other country, let me know to guide you more.
Thank you.
Dec 09, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Black LCD screen/ not 'seeing' picture. Canon EOS 400D camera
Hi
The Digital Rebel XTi doesn't have 'live view' mode, you can't see what you're taking a picture of before you take the picture.
Thomas
Darntoothysam com - Digital camera parts and repair.
Nov 11, 2008 | Canon Rebel XTi / EOS 400D (body only)...
Camera turns on, but no screen visual
You may have accidentally hit the DISP button on the back of your camera. This button manually turns the screen on and off to save batteries. Turn on the camera and press it once to see if that corrects it.
Jun 26, 2008 | Canon PowerShot SX100 IS Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Motorola Mobility W375 Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
