Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Kenmore ultra wash 16765691
Fills with water but wont wash . If I add a few extra bowls myself it will work.
  • wade0117 Nov 21, 2008
    leakes under door by the louvers slotes when in use
5 Suggested Answers
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
  • 423 Answers
SOURCE: Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
Posted on May 04, 2009
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
  • 67 Answers
SOURCE: I have a Kenmore Ultra Wash Plus, Model # from
THIS SOUNDS LIKE A BAD MOTOR
Posted on Aug 11, 2009
Kenmore 800 washer fills with water and then empties immediately
Go to www.repairclinic.com Add your model number and then follow a few do it your self procedures to help you fix it.
Nov 01, 2016 | Kenmore Washing Machines
My Kenmore ultra wash 6651736 dishwasher broke almost to the month it turned 6 years old and I'm trying to decide if I should fix it or buy new.It washed wonderfully up to the day it stopped .the water...
very common issue on these units, the motor had failed, the motor did have a five yer warranty but we are beyond that.
You can purchase the part from the link below,
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Kenmore Dishwashers
I have a Kenmore Ultra II 90 series washing machine (#11092561400) it fills & agitates but wont drain & spin/rinse? Any solutions.
lift the lid up a few inches and close it down a few times,if you don't hear it clicking you have a broken lid switch,also try to stick a pen or something in the hole on the top and see if it spins,let me know what you find
Aug 27, 2010 | Kenmore 22422 Top Load Washer
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
My spin cycle will not work
replace coupler, you have to remove case
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
I have a KENMORE Model 665 Ultra Wash
run the washer first with nothing in it. see if your still hear the noise. only time it should make any noise is if there is not enough water also rotate the bottom jet and see if it turn s smood.
Oct 16, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
258 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
