Question about LG LRSC26910 Side by Side Refrigerator
Water wont shut off
The water will not shut off from the dispenser, had to cut it off from the wall
  • 489 Answers
You have a problem with either a sticking dispenser switch or a sticking relay problem.  You will need to have a qualified LG technician diagnose the repair the problem.
Posted on Jun 08, 2008
Electrolux water dispenser wont shut off
If your water dispenser will not shut off then it is either the dispenser microswitch or the water inlet valve in the back of the refrigerator. Here is link that might help http://apcoappliancerepair.wordpress.com/?s=water+dispenser . Would need a model and serial number to assist you more. Good Luck From Apco Appliance and Air .
Apr 19, 2013 | Electrolux Refrigerators
Water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
Apr 21, 2012 | Refrigerators
No water from dispenser
I had the problem with the water dispenser not working.i tried all kind things finally I figured out the water was freezing ing the door. I cut a piece of 1/2 styro foam out that covers right below where the ice is dispensed just a square and use double sided tape to stick it to the back side of the door and haven't had anymore problems.
Nov 13, 2009 | GE Refrigerators
Rs2544sl water wont work
You push the water dispenser lever in and it applies power to an electric valve (solenoid) which opens and allows the water to flow.
So, there are two components to look at: 1. the electrical switch attached to the lever; 2. the solenoid valve.
Secondary things to check: Is the water connected? Is the shutoff valve on the wall open? Is the tubing clogged with mineral deposits? Are any wires for the water dispenser switch or solenoid disconnected, chewed through by that dead (electrocuted) mouse under the refrigerator?
Hope this helps...
Good Luck!
Oct 10, 2009 | Refrigerators
Push the water dispenser, water starts but then stops abruptly
Yes , replace the water inlet valve . The piece the wall water line connects to .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/valve....no water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
Water dispenser wont shut off
Something from the filter went into the dispensor valve and is holding it open. You can try to backflush it with a can of air by disconnecting the filter pushing open the valve while holding the can straw tightly while discharging it. You could also backflush it with water.
Jan 12, 2009 | LG LRSC26910 Side by Side Refrigerator
Wia111
First check whether your inlet valve is open on the wall; if that is not the problem check to see that the inlet valves are not clogged with some dirt or something, clean out and refit. Plug off the wall and careful with the water spillage. The final part should be to check whether the water flows into the machine, ie. the entry at the soap dispenser. Simple.
Sep 01, 2007 | Indesit WA 115 Front Load Washer
LG LRSC26910 Side by Side Refrigerator Logo
270 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
