Question about Fuji FinePix Z1 Digital Camera
Dpi issue In the f-Mode menu I have set my camera to the highest available quality, ie: 6Mf. However, when I open the pictures on my PC (in any of the proprietary imaging software), it shows as having a resolution of only 72 dpi. For print purposes I need to achieve at least 300 dpi (600 preferable). This is not a memory issue as I have a 2gBt memory card. Can anyone advise? Please note my camera is a Fuji FinePix S6500 fd John Tomlin jt@johntomlin.me.uk
  • 871 Answers
Hey john
try to increase the iso level on your camera. this will or might increase the dpi solution on your computer. the higher the filesize and resolution, the higher the dpi.
with regards to coolguy008 post, you must indeed try to switch it to a different mode to achieve a higher resolution.
thanks for using fixya.
Posted on Apr 01, 2008
    Genius:
  • 3,422 Answers
Here is the solution to your problem.You will have to refer the user manual for some troubleshooting steps.
Click HERE to download the manual.
Goodluck,
Please don't forget to rate the solution
  • Priya darshan Apr 01, 2008
    You will have to use external controls to change to 640 x 480 or 320 x 240 pixels, both at 30fps.
    Mode Switch
    : At the right hand side of the camera's
    top panel, this switch controls the camera's exposure modes. Options
    are Still Image, or Movie (Movie records moving images with sound, at
    either 640 x 480 or 320 x 240 pixels, both at 30fps.)
  • 818 Answers
    Genius:
  • 1,913 Answers
Reset your camers settings.
Setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Nov 30, 2012 | Nikon D3100 Digital Camera
I am using a Fujifilm FinePix JX250 digital camera. Not the best I know to photograph jewelry but cannot afford a different camera now. After I've taken the picture I open it in IPhoto. I make...
The following will help to get the best possible pictures from your Fujifilm FinePix JX250:
TO CHANGE FILE SIZE:
  1. Press MENU/OK to display the shooting menu.
  2. Press the Selector UP or DOWN to highlight the option IMAGE SIZE and press the selector RIGHT to change IMAGE SIZE to 14M. This setting has a image resolution of 4,288x3,216.
  3. Press MENU/OK to select the highlighted option.
  4. Press DISP/BACK to exit from the menu.
TO CHANGE QUALITY:
  2. Press the Selector UP or DOWN to highlight the option IMAGE QUALITY and press the selector RIGHT to change IMAGE QUALITY to FINE (Less compression than NORMAL, meaning better picture quality).
NOTE: The focus range of the JX250 goes from 1.5 ft. - Infinity (Wide Angle), 2.6 ft. - Infinity (Telephoto), also make sure to clean the lens and adjust the focus before taking the photos. If the subject is close to the camera, select Macro mode. If the subject is far away from the camera, cancel Macro mode.
May 28, 2011 | Cameras
Gambar kurang terang
Hello, P'Hendy
This can be caused by these things: 1. Bad Camera settings. Make sure to set picture quality to highest and set your flash correctly while take pictures ( or just set it in auto). 2. Bad The printer. Have you use good printer? I suggest you to use printer with capability up to 4800 dot per inch (dpi) 3. Bad ink and paper. You should use good quality ink and photo paper.
Nov 29, 2010 | Nikon COOLPIX S230 Digital Camera
TIDAK BISA TERANG HASIL CETAK GAMBARNYA
Hi, P'Hendy
When I turn camera on to take picture, I get a screen that says "1M 423". It is set on "Auto" which is also indicated on the viewing screen. How do I fix it?
"1M" stands for 1 megapixel. The camera is set take pictures in 1280x960 pixels mode. To change this press the F button and select another mode. 6M is the highest quality, but will reduce the number of pictures, you can take before the card is full. "423" indicates available space on the card. This number gets lower as you increase quality.
May 26, 2010 | Fuji FinePix S5000 Digital Camera
Photo resolution
Sony H1 takes photos at 72 dpi by default. But the picture quality will be good. if you want to convert it to 300dpi open the picture in adobe Photoshop and select image size and change resolution to 300 dpi. but the file size will be very high to up load. if you want to reduce the file size select the image size in adobe photoshop and reduce it according to your requirement. if my solution proves good please rate it. Regards.
Feb 04, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Setting dpi on canon ixus 800 IS
You can download manuals here.
As dpi is generally a printing specification, the size you set on your camera depends on what size prints you want to make. If you want to print 4" x 6" prints at 300 dpi, you can set the size to M2. If you want to print 5" x 7" prints at 300 dpi, set the size to M1. Anything larger, set the size to L. With L selected, an 8" x 10" will still be about 300 dpi, but any larger print will be at less than 300 dpi.
May 15, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
DPI resolution
menu- camera set up- picture quality- try to locate picture size using menu button switch. RAW file is the best but it eats too much memory.
Sep 07, 2007 | Canon Digital Rebel XT / EOS 350D Body...
How do I setup the camera to save pics above 180 dpi resolution?
Select image>image size, make sure that the 'resample image' box is unticked and change the resolution to 300 dpi. This will automatically change the image size.
Sep 14, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Fuji FinePix Z1 Digital Camera Logo
247 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
