Question about Microwave Ovens
Microwave just suddenly stopped working with no other previous symptoms.
  • theryan21 Sep 30, 2008
    my microwave will come on, it will do everything but no heat is coming out, it wont cook anything!! just started doing this out of the blue! help!
  • Anonymous Jan 19, 2009
    it went dead almost immediately after pressing the Start pad
  • Microwave Ovens Master
  • 9,174 Answers
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For many brands and models, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 01, 2008
SOURCE:
My microwave oven suddenly stopped working. It is plugged in and I checked the circuit breaker. Can I fix it?
If fuses have been checked and since you have had previous problems there is nothing else really you can do other than buy a new one!
Oct 21, 2014 | Microwave Ovens
Hamilton beach microwave stopped working suddenly. attempted to heat a breakfast sandwich...and it stopped working after heating a food item moments before. I purchased the microwave within the previous...
Typically, you have the first 30 days to exchange a new purchase. I would pursue that avenue. If you bought it online, it's probably freight related. Try to file a claim..
Oct 31, 2013 | Hamilton Beach 1.1 Cu. Ft. 1000-Watts...
Had problem with Sharp R-520L. Microwave suddenly
One of the door switches is the problem. Open the casing, and you should find the schematic diagram. Find the switches, and test if you can. If you cannot - replace all of them except the monitor switch.
Nov 17, 2009 | Maytag MMC5000 Microwave Oven
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Replace fuse in sanyo em-z2000s microwave onen
try replacing the fuse.there might just be a voltage fluctuation in your locality
Mar 16, 2009 | Sanyo EM-Z2000S Microwave Oven
Microwave just stopped working
  • Internal fuse may have opened
  • Door interlock may have failed
  • Magnetron may have failed
  • Control panel may have failed
Jun 19, 2017 | Sharp R-1492 Microwave Oven
Sharp Microwave R-520L stopped working
My parents had the same problem. It turned out that a switch went bad. When you take the case off, there are 3 switches where the door latches. The bottom switch went bad. It is an Omron D3V-16G-3C25 switch.
Nov 13, 2008 | Maytag MMC5000 Microwave Oven
Danby Designer microwave (with exhaust fan mounted above stove) stopped working suddenly. Lights are on and microwave sounds audible but no heating of food kept inside.
With these symptoms I would suspect a bad magnetron or a loose connection at the FA terminal of the magnetron.
I would suggest you contact Danby customer service o locate their nearest authorized servicer.
Jul 08, 2008 | Danby Microwave Ovens
Kenmore microwave
The Keypad is a Circuit.Each of the Function Buttons is a switch. The same "Touch" Techinology as is used of your TV Remote Control Pad or your Telephone. It would appear that your Keypad Circuit is Open, not allowing touch commands to reach the Control Board.The Keypad will have to be replaced. Best done by a Professional. I have seen "Rare" cases of a defective Door Switch causing such symptoms.
Jan 26, 2008 | Microwave Ovens
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Microwave Ovens Logo
307 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
