Question about Palm IIIxe Handheld
Palm IIIxe backlight
Bought a used Palm IIIxe and the backlight does not work. I hav e correct AAA batteries in and I know to push and hold the power button but still no backlight. Please advise. Do I, for example, need another type of internal battery requiring the back to be unscrewed and opened?
Peggy
    Problem Solver:
  • 16 Answers
No, the backlight seems to be about the first thing to go when these screens fail. You can possibly get a replacement screen from pdaparts.com.
Posted on Sep 22, 2009
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
Tried to start up Palm IIIxe after a couple years and it seems to not work at all. Is there a trick or something special that needs to be done to it? I tried the reset button, but that didn't work either.
A very basic question would be if you've fully charged the battery pack. It is very likely to have gone dead in the interim, which means you'll have to reload everything (other than the ROM-based software that came with it) once the unit returns to life.
Apr 13, 2010 | Palm IIIxe Handheld
Would like to know how to load or play games on my palm.How do utilities work. Is there software and programs I get? K.C.
Without knowing what version of Palm you have I cannot give a 100% accurate answer. I can refer you to websites that have games for Palm Pilots and for Palm OS phones Website are listed below:
www.palm-games.com
and
www.palmgames.com
Nov 14, 2009 | Palm IIIxe
My new Vista system cannot read the PalmIIIxe I have in the old HP machine. Is there an upgrade?
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Sep 15, 2009 | Palm IIIxe Handheld
Palm iiixe installation
The problem has been resolved, thank you.
Dec 15, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Palm iiixe will not turn on and the batteries check out fine.
It died. Accept it and move on. Probably want to consider buying an up-to-date PDA (like an Apple iPOD Touch!).
Nov 24, 2008 | Palm IIIxe Handheld
Just a question. Can I download my palm desktop address book from my IIIxe to a neww Z22 handheld unit?
I went to Best Buy and bought a Palm Tungsten E2. Download was easy, and I have all items from the old IIIxe on the new unit.
Sep 17, 2008 | Computers & Internet
My Palm Zire 72 will no longer charge
At first, before to want to be sure where is the problem is, you must do these sample tests: 1) Take out your battery and plug your power cord into your phone without battery. If : Power is on, there is definitely, your battery is bad and cannot hold a charge. If nothing happens, your internal battery may be dead and cannot hold charge so all info in your ROM of course has been washed away except the pre-load software by Palm. 2) At this step, you need to open your Palm if you know how to do to check for any bad connection between cable and use your volmeter to check the voltage output of your inner battery or can be called reserved battery whether it is have any power. If your reserved one has correct output voltage as in specs then check all connection around your power supply part to see any crack or defect. Please reviews the link below for detail: http://palmtops.about.com/od/pdarepair/Maintenance.htm I hope these info will give you some hints.
Apr 10, 2007 | Palm Zire 72 Special Edition Handheld
Sandisk e130
Get out the battery and let the device "calm down" without any source of power for 5-10 minutes. After that push the menu/start button, hold down for 30 or more seconds and holding down, insert the battery. It has to reset the power circuitry and should help.
Feb 25, 2007 | SanDisk Sansa e130 MP3 Player
Outlook will not sync with Tungsten C
Check you sync part of your desktop program and make sure you have outlook checked for transfer. Right click on Synch on bottom tray and select custom set uo
Sep 11, 2005 | Palm Tungsten C Handheld
Palm IIIxe Handheld Logo
78 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
