FixYa.com
Tags:
Emerson MW8107WA 1000 Watts Microwave Oven
Emerson Micorwave Model No. MW8775W
posted by steve10466 on Apr 01, 2008
Does not power on, no power to unit when press start button
any idear would be apreciated
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 01, 2008
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2376 votes
(We have already spoken once on the phone, but I'll go ahead and post for you and for others).
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Rating Locked! (?) steve10466 has rated this solution as FixYa!
Can you Help with these Microwave Ovens problems?
Microwave Ovens
JE1860SB 001 model
Small flames and then flashes... Answer This...
Microwave Ovens
10000W Microwave Oven When...
10000W Microwave Oven When... Answer This...
emerson 1000 watts
i have power, but button will... Answer This...
Comes on but........
The microwave and light comes... Answer This...
water has penetrated inside the...
when I was cleaning the door, I... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
