Question about RIM BlackBerry Pearl 8100
Blackberry Keeps Freezing Up
My blackberry screen just freezes up periodically and I have to take the battery out to make it work again. Is this normal? The device is only a few months old.
  • Anonymous Apr 18, 2009
    My blackberry pearl recently froze, the red LED starts flashing and the screen turns white and a little hour glass appears, its been like this all night...I've also taken the battery out, when i put the battery back in the same thing occours...i cant turn off the phone or anything..pls help me
    Sergeant:
    Champion:
  • 221 Answers
It is not supposed to occur in a Normal Phone. You should try formatting the Phone (Don't forget to make a Back-Up Copy of the Data in your Phone before).
Posted on Apr 02, 2008
SOURCE:
My blackberry 9700 keeps freezing please what can I do?
You need to restore/reset the phone with blackberry manager. Connect the phone to your PC, lunch the blackberry manager and proceed for the restore.
You can download the manager from blackberry.com
Jan 25, 2012 | RIM Cell Phones
My phone keeps freezing up? I can take the battery out then itll reboot itself and work for a few minutes then it freezes up again and nothing will work I have the blackberry storm 2
you can update with blackberry desk top manager it will find upto date software for your phone and should cure your problem but you need to back your phone up and your pc needs to be connected to the net
regards
Dec 17, 2010 | RIM BlackBerry Storm 9530 Smartphone
My blackberry phone keeps freezing up and the hourglass keeps showing up
this can sometimes happen to blackberries. and there is not easy fix. there are applications for the blackberry that you just click on to do a soft reset. this program was created because of this issue. if this does seem to help and you don't want to keep resetting your phone, you might this about doing a wipe and starting from scratch. you might have downloaded a program that just is not working properly...good luck
May 04, 2010 | RIM BlackBerry Curve 8300 Smartphone
My altell blackberry flip keeps freezeing up
See how much memory you have left. If you have a blackberry the first thing you want to invest in is an SD card and good memory management is your best friend. Otherwise, since the working memory and the storage is the same general pool of memory, the device can run very slowly or lockup entirely if you have too many active applications running.
Feb 02, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
My 8120 blackberry pearl keeps freezing and losing / deleating texts
you might need to try pulling the battery every once in a while. or getting rid of apps you don't use on your bb. or you could try getting an SD memory card because 9 time out of 10 its memory problems that make your phone freeze. good luck hope i helped :)
Jul 14, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Freezing Blackberry
have you removed the battery and put it back in.
his will reboot the software.
also make sure your battery is up to par, the battery in a blackberry when they get used for a while need to be changed, your phone is very graphic intensive and needs a very good battery to run without problems. replace the battery and see what happens.
Jun 03, 2009 | RIM BlackBerry Storm 9530 Smartphone
Keeps freezing and rebooting
Most likely this is a memory issue.  Go in to your options and advanced settings to check for available memory. Remove programs you do not use.  I am posting a link below that will help you free up memory.
http://crackberry.com/blackberry-101-how-free-memory-your-blackberry-smartphone
Hope this helps.
Apr 21, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry rim 7250 keeps freezing and it will have an hour glass that is running. I have to keep taking the battery out and then it works fine for a little while. Any suggestions??
Sounds like you have a curropt application. Wipe the Device from the settings menu.
This will bring the device to standard settings.
Hope this helps,
Thanks.
Mar 06, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry keeps turning off and freezing
Sounds like the device need the lastest firware "device Software" installed. You can do that from the Desktop Manager.
Download the latest "Device" software from www.blackberry.com
Hope this helps, please don't forget to rate me.
Thanks.
Jan 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry  Pearl  8100 Logo
1,356 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
