Every few days a small window appears saying no signal. as it happens my comp is on 24 hours a day so why does it suddenly say no signal. and then the monitor turns off every 3 minutes and comes on again. the only solution is to turn the comp off for a while, but i like to have it on all the time.
  • sevron Apr 01, 2008
    its not a computer problem. its only the monitor.
    it will take a bit of time but i will try it. thanks.
    Genius:
  • 1,913 Answers
Check your ram clean it and also your ram slot.
then if pro.replace your ram and try
reply me pls
Posted on Apr 01, 2008
  • kishor khatri
    kishor khatri Apr 01, 2008
    OPEN YOUR MONITOR REMOVE DUST FROM IT.
    REATTCH ALL CONNECTION.
SOURCE:
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
Need instruction for setting time of day
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Paragon 1015-00RS Indoor Multi Operation...
Bushnell 7 day forecaster. My screen does not display information and says that the network is lost or in network - please wait 1 hour. It's been more than an hour it's been a few days. I have changed the...
I have a Bushnell 7 day forecaster for about 10 years I love it . Suddenly one morning it lost its signal and no matter where I placed it I would receive a message from the unit no signal found try another location . Loosing my owners manual IN THE BACK OF THE FORECASTER AND THERE IS A SMALL RESET BUTTON ON THE BOTTOM I TOOK A SMALL PIN AND PRESSED THE RESET BUTTON AND IT WORKS PERFECTLY now Hope this can help who ever has this issue , note the smaller five day forecasters do not come with a reset button in the back.
Feb 03, 2011 | Bushnell Measuring Tools & Sensors
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Just bought a Fossil FS4446 sports chrono but it looks like the hour on the chrono is stuck just after 19 on the small dial on the right i just want to check that this is indeed the hour dial. and if it...
The small dial on the right is 24 hour counter and it does one full circle in 24 hours. The purpose of this counter is to tell the wearer what part of day or night is exactly (p.m. or a.m.). There are some places on our planet where the night/day lasts for months and it would be difficult to realise it's morning or evening without 24 hour counter. Try to advance watch hands forward/backward for few hours and you will see this counter hand moving. If it does not move, your watch has faulty/broken wheel and needs to be sent back for replacement/repairs.
Jan 27, 2010 | Finis Watches
We have Subzero 550 that suddenly is running warm @50 F. It made a rattling sound during the day which has stopped. Any thoughts about cause and cost of repair...jem
compressor probable let cool a few hours then try to restart.if compressor maybe worth replacing unit depending on age avg 200+ for comp replacement ?
Jan 16, 2010 | Refrigerators
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
P2015DN Left side of image cut off
If this is a HP LaserJet P2015dn Printer try the 24 hour # listed below.
I've spent countless hours trying to install solve printer problems by going on line but I eventually solve the problem when I break down and call the 24 HOUR NUMBER!
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products
Be prepared to provide the following information: Serial Number (S/N), product name, model number
HP TouchSmart PC products
866-408-5408
24 hours a day, 7 days a week. U.S.: English and Spanish.
Compaq Presario PC products 800-OK Compaq
or
800-652-6672 24 hours a day, 7 days a week U.S.: English and Spanish. Customers using TTY 877-656-7058 6:00 a.m. - 3:00 p.m. PT
Mon. – Fri.
excluding holidays
Dec 15, 2008 | HP LaserJet P2015dn Printer
Mushy after less then 24 hours
It's not meant to keep in there for a few days. A few hours would be the max, say for a party for instance. When you are done with the rice, take it out and put it in your refridgerator.
Sep 12, 2007 | Zojirushi NS-PC10 5-Cup Rice Cooker
Computers & Internet Logo
27 people viewed this question
Ekse
Alun Cox
