Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Will not run unknown light on
My dishwasher will not do anything. There is a little pad lock icon under the heat dry button that is lit up. I have no idea what it is or how to get it off.
  • 1 more comment
  • pinkturtle Apr 01, 2008
    Thank you soooo much.
  • 2kimpossible Jul 04, 2008
    same problem-will not run unknown light on problem
  • Anonymous Mar 28, 2014
    Will not start and no buttons light up except the heat dry button
  • 4 Answers
PRESS AND HOLD THE KEY WITH THE LOCK UNTIL THE LOCK LIGHT GOES OUT.
Posted on Jul 10, 2008
    President:
  • 1,314 Answers
NO-HEAT DRY / COOL DRY for 5 seconds -the controls are locked you can unlock or lock them this way
Posted on Apr 01, 2008
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
flashes 3 times.
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
There is a lock button and it is lit, how do i unlock it?
Hello & Welcome to FixYa
To unlock the controls press and hold the HEATED DRY/AIR DRY/RINSE ONLY button for 20seconds. If the problme returns then only option is touch pad replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Frigidaire Dishwashers
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
I have a sears dishwasher, lock light is lit but
Press and hold the 'Heated Dry' button for 4 seconds then let go
Apr 24, 2010 | Kenmore Dishwashers
My Maytag Quiet Series 300 light is blinking 5 times by the lock button. It won't do anything else other than blink 5 times if any other button is hit. Help!!
When Control Lock is lit, all buttons are disabled. If you press
5 times. The dishwasher door can be opened while the
To turn off Lock, press and hold Heated Dry for at least
3 seconds.
Dec 30, 2009 | Dishwashers
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
To turn on the Lock
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
GE dishwasher won't start
You have a washer control board problem or a burnt connector or both.
Mar 17, 2017 | GE 24 in. Profile PDW9200J Built-in...
Padlock icon light is on
you have engaged teh lock out feature, simply push in the control lock button for 3 secs to unlock not a problem! look close at the buttons,ones marked "contol lock" in small print under it, usually the heat dry button
Nov 17, 2008 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
665 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
