When i turn it on
I have a shuttle xxpc when i turn it on nothing happens ie the computer doesn't make that beeping noise, in the past it has happened and said something like CMOS battery error reset CPU frequency
    Genius:
  • 3,422 Answers
HI,
Here is the fix to your problem:
Take take out the battery out for about 5 minutes, turn off the PSU at the back too.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 01, 2008
  • 818 Answers
General FAQ | 2008/03/17 What do I do if my system fails to boot-up or hangs at POST?
The first thing to do is to shut down the system and clear CMOS with a jumper. Then check all hardware devices systematically, including CPU, RAM, VGA, AGP and power supply. Check that your CPU, RAM and AGP are supported by your system (DDR and AGP support list is only available for XPC). If you are still unable to resolve this issue, please contact your local reseller/retailer (point of purchase) for more directions, and if necessary send it in for service.
  • 813 Answers
Hi frineds
u have problem in ram so remove ur ram clen it reinstall
i hope ur poblem solves
    Genius:
  • 1,913 Answers
Hi
clear your bios setup with jumper settimgs.
also put away the cmos cell from its case for 15 minutes then reattch it.
then start system.
also check ram clean it.lean your prosesoor case.
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Tip
Computer beeps
If you try to power on your computer and nothing happens but a bunch of beeps there is something you can do. The beeps actually mean something. To make sure you can hear the beeps check in the bios options. If there is an option for a silent boot you won't hear any beeps. If you hear one beep every time your computer starts then you don't have to worry about this.
If you want to check this setting refer to my other tip on how to enter bios and change boot settings.
If you try to boot your computer and nothing shows up on your monitor do these steps first.
1-Check all your cables in the back of the computer.
2-check your power source and power cord to the monitor
3-try another monitor if possible
4-If on a power bar try to turn off the power bar and reset the breaker
If you try to boot your computer and nothing happens and you hear beeps look at this website. The beeps you hear are actually telling you what is wrong. Look at the website by clocking on the link below and click on the computer beep codes link. If you want to scroll down past the link it will show you bios codes to enter the bios in your computer
http://www.michaelstevenstech.com/bios_manufacturer.htm
on Jan 28, 2009 | HP Compaq Presario SR1500NX (PX786AA) PC...
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
I have a simplex T2 DL2700 I put in the code the light turns green but nothing happens. It you use to make a noise and unlock now it doesn't do that any more.
Trilogy Locks
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version.
Jun 27, 2011 | Trilogy Alarm Lock T2 TRILOGY Digital...
I have a beeping noise on my computer.
Beeping noises are very common. The problem is that beeping is so common that it could really be any number of things. Is the beep happening when you try to turn the computer on? Does it get all the way to Windows? How many beeps, short or long? Please be as descriptive as possible.
Oct 19, 2009 | Computers & Internet
When i prest the reset button it dint do nothing when i turn on the power nothing happens the monitor is black
The rest button Will Only Work when the computers Running.
When You Say " Nothing Happens " What do you Mean ????
Are There Any lights on the Front Panel ???
Can You Hear Any Sound Or noise ????
Does The Computer produce Any Beeps ???? if So How Many ????
Have you Plugged It In ????
Has The Fuse In The plug Blown ?????
How do you expect suggestions, From such a Simple Question ???
Mike @ Compurepair.
Who Thinks Fixya, should Vet the questions and the Questioners, Rather Than The Experts :-)
Aug 19, 2009 | Shuttle XPC SK41G (XPC-SK41G-SHUT) PC...
Computer goes on but does not boot
When you start up the PC, do you get any kind of beep sound? If not, I would reckon the RAM modules are faulty and would need to be replaced first. That is the usual cause for this kind of issue. Also when replacing the modules, make sure they are the type supported by your motherboard, ie DDR, DDR2, etc. You will have to consult your m/b manual for this..
If the problem is not with the RAM, ie you hear a beep, but nothing else, I would guess that the MBR of your operating system is dysfunctional, which would mean that you would have to reinstall the operating system.
Hope that helps...
Cheers!
ID
Oct 28, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
No signal input
Check the coolant between the CPU and the cooler to ensure it's not simply over heated.
May 30, 2008 | Acer AOpen AX 6B Plus (91.87810.321)...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
