Question about Dryers
I'm trying to replace the rear drum in my dryer I have taken the top and front off and disconnected the belt cannot get the drum to come out
    Scholar:
  • 178 Answers
Raise up on the backside, Top of the drum and it should snap out of it's bearing holder. After it releases from the bearing holder, you should be able to pull it out of the front of the shell.
Posted on Apr 02, 2008
SOURCE:
I need to change the dryer belt.
  1. Disconnect the dryer from the electrical supply. The easiest way to do this is to simply unplug it from the receptical. This will prevent accidental electrical shocks and burns.
  2. Move your dryer to an area where it will be easy to access the rear of the machine if possible. This means disconnecting the vent duct and unplugging the electrical power if not already done. If the dryer is ducted in with solid metal pipe, or hardwired into the home's electrical power, you may need to reconsider doing this job yourself. Do not attempt to loosen or disconnect the gas pipe (from any gas appliance) in order to move it. Even a slowly leaking gas pipe is a very dangerous condition that will eventually ignite with potentially deadly results.
  3. Check the outside of the machine near the top for any exposed fasteners. Most dryers built in the last 20 years have hinge-like clips on the rear, and snaplock fasteners under the top to make removing the top easier. Check at the lint filter access door for additional fasteners, usually counter-sunk phillips type machine screws.
  4. Remove any fasteners, either at the lint screen access, or the top rear of the dryer, putting them in a safe location for reuse when putting the machine back together. Most dryers body screws are either 1/4 inch or 5/16 inch machine screws, so a nutdriver of the right size will make this job easier, but even a pair of common pliers will do in a pinch.
  5. Pry the front of the top of the dryer up with a large flat-bladed screw driver to disengage the snaplock that holds it in place. Be careful not to twist or pry in such a way that the screwdiver slips and scratches or chips the finish. Once it is free of the locking ring, you can lift the cover high enough to see the top of the dryer drum. You should see a narrow reinforced rubber belt wrapped around the drum. If it is missing or very loose, you will need to proceed with replacing it. If it is still in place on the drum, you may have a problem with the electric motor which turns the drum or the electrical switches that control the dryer's functions instead of a belt problem.
  6. Unplug the electrical wires at the front of the dryer that connect to the door safety switch. There is usually a plug connector on the wiring harness to make servicing the drum area easier, but if there is no apparent removable connector, you may have to cut these wires and reattach or splice them when you reassemble the machine.
  7. Lift the top of the machine at the front, allowing it to hinge back on the rear of the machine. Watch the wires from the timer and machine controls so that they do not tear loose from their terminals or snag on a sharp metal edge when doing so.
  8. Prop up the top of the dryer with a chair or other item so it is supported while you work on the drum and belt assembly. You may find a volunteer to simply hold the top up, but fitting the belt onto the motor and around the drum can take time, so having something to support it will make the job easier.
  9. Lift up on the front panel of the dryer. There are usually two friction type clips that fit a slot on the front panel, securing the bottom of the panel to the sides of the machine, and lifting this part will allow it to be removed so the drum can be taken out. If lifting does not free the front panel, check underneath the machine for concealed screws or other fasteners. If none are located, try prying the front free.
  10. Hold the front edge of the dryer drum, and remove the front panel entirely, placing it to the side. Now you are ready to slide the dryer drum out of the dryer housing. If the old dryer belt is still attached, you will need to slide it off the drum so the drum can be removed, or cut it and simply pull it out.
  11. Pull the dryer drum forward while balancing its weight, and remove it from the dryer housing.
  12. Take the old belt and any information from your dryer to an appliance parts supplier to match it for a replacement. Some dryer manufacturers do not have aftermarket replacement parts suppliers, so you may find you have to locate a dealer for your particular brand of dryer.
  13. Clean any lint, trash, or other debris from the dryer's housing. If the lint filter ductwork is removable, now may be a good time to do so and clean it, as well. Wipe down the drum rollers and guides while you have the drum removed as well.
  14. Wrap the new belt around the drum when you are ready to reinstall it. Observe the drum, you should see a mark where the old belt fit the drum, and make sure the new belt is set at the same location. Slide the drum back into the machine, and support the front of the drum to hold it in position.
  15. Lay down in front of the dryer, and look underneath the drum to the belt tensioner and the electric motor that turns the drum. Fit your new belt through the tensioner and around the pulley on the motor, making sure the traction grooves are facing the pulley in the correct fashion.
  16. Slide the front cover up to the front of the drum, removing any support blocks from underneath the drum when you do so. Push the front completely in, lifting it over the latches and allowing it to drop onto them to secure the bottom in position. Push the top in, making sure the seals fit inside the drum snugly, without damaging them. These seals are usually felt, or some other soft material, and are held in place with an adhesive.
  17. Replace the screws removed to take the front panel off in the reverse order they were removed in, making sure you plug in all electrical connections as you do so. Let the top of the dryer drop down into position, and press at each corner to engage the snaplocks. Check to make sure all additional fasteners are replaced and tightened snugly.
  18. Replace the dryer in its usual position, and reattach the dryer vent ductwork. Make sure this ductwork is clean inside, since lint bypassing the lint filter can eventually stop the duct up. Plug the dryer back into its receptacle and turn it on to test it.
Hope i ve been of help.
Thanks,
Jun 21, 2011 | Dryers
How remove front panel of frig gas dryer faqg7077kw
Hello there:
Here is how to disasseble the dryer
White/Westinghouse - Frigidaire style dryers- How to take apart....
White/Westinghouse, Frigidaire style dryers ( some 417.######## Kenmore dryers ) - How to take apart:
Disconnect power first In order to test and effect repairs on any product, you must be able to disassemble and reassemble the appliance. So lets start with disassembly on this dryer. Unplug the dryer. Get the top up by pushing in on 2 clips on either side as shown in this picture. We need to remove the front of the dryer next. There are 2 or 4 screws inside at the top on most of the older dryers that we need to remove. Once the screws are removed, you can pull forward on the front and lift the complete front off the 2 clips on the bottom of the dryer. Unplug the door switch wires and set the front aside.
if you need to further dissassemble it follow the next steps
Next step in disassembly is to remove the belt from the idler and the motor pulley. This is done at the rear of the dryer. Remove the 2 screws holding the inspection plate on the left rear of the dryer. Remove the plate. Look carefully at how the belt threads around the motor pulley and idler pulley so you can replace it. Remove the belt from the motor pulley. Return to the front of the dryer, grasp the belt in one hand and the front of the drum in the other hand. Lift up on the rear of the drum and pull forward with the other hand. There is a ball on the rear of the drum that rides in a socket located in the center of the back of the dryer. You are lifting the knob up and out of the socket. Look in the center of this picture for the socket. You have taken the dryer far enough apart at this point so that you can accomplish any repairs needed on this style dryer. It is not necessary to go this far for all repairs, but if you need to disassemble, you have the information.
Jan 09, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
My whirlpool LGR8648twg is squeeking when it runs . I would like to oil it. How do I do that
Don't oil anything...it makes a mess and if you get it on the belt you'll be replacing it and doing a lot of cleanup.
Replace the idler pulley and drum support rollers. This will likely stop the squeaking.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
Take careful note of belt configuration BEFORE removing drum. Draw a diagram of its travel. Take care not to touch or hit the ignitor on the gas valve or you will be replacing it also. It is VERY brittle. After drum removal you will see the two drum roller attached to the rear wall. Replace them along with the idler pulley for the belt.
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Check the rear seal of the dryer drum to be sure it's flat and not curled under. Use your fingers to uncurl it all the way around.
Reverse process to re-assemble.
Motor and idler pulley for dyer will be on right. Gas components will be on left
Sep 10, 2009 | Whirlpool LER4634J Electric Dryer
How to remove the drum from the front and replace the drum support cup kit.
Release the top by pushing in the clips with a putty knife at the front right and front left of the dryer. Once you release the top you can remove it by disonnecting the ground wire at the rear of the top panel. Remove screws that secure the front panel to the dryer. Once all the screws are removed give the front panel a tug to pop it from the clips. Unhook the wiring harness and remove the front panel. By now you can see the drum. Remove the belt from the motor and idler wheel pulley. Yoy will need to get to the rear of the dryer and remove a grill (lower left corner).to gain access to the pulleys. Once the belt is removed, grasp the drum at the rear and give it a quick **** upward to release the drum from the rear bearing. The drum can now be removed through the front.
If you are replacing the rear bearing, consider also replacing the front plastic glides/slide that are located at the top of the door.
May 23, 2009 | Frigidaire FDE647RF Dryer
The dryer is humming but not spinning when i removed the top cover i see the belt in the middle of the drum. Do you know where it supposed to go?
is belt disconnected? Is belt broken? Will dryer rotate manually? if so ,
I suspect that the belt broke. order a new belt Home depot has a good parts service or try other local appliance places. You will have to disconnect power first, Remove front panel to access drum Dont forget to unplug door switch there should be a plug front top right, in the rear on the bottom there is a motor and an idler/tensioner. install the new belt and under tensioner Yes the path will seem awkward and re assemble. Also now is the time to vacuum lint out
Dec 30, 2008 | Roper RGX4634KQ Gas Dryer
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Belt broke on GE Dryer model #DDE7500BALWH
You will need a WE12X82P belt, or just a WE12x82 (the P stands for packaged)
  • Disconnect power
  • Remove screws under the front edge of the dryer top
  • Swing top up and remove one screw from each side panel holding the dryer front, near the top of the dryer.
  • Pull dryer front forward a bit and lift off bottom pegs. Swing to the side. (no need to disconnect wires if you don't want to)
  • Put belt around drum, lifting drum a bit to get belt past drum support slides on the bottom side.
  • Check to make sure drum slides are not worn through, especially the one on the left side.
  • The grooved side of the belt touches the drum
  • Belt runs from drum directly to motor pulley on the left side, then around belt tensioning wheel and back to the drum.
  • Turn the drum a revolution or two (counter clockwise) before reassembly.
Oct 04, 2008 | Dryers
Replacing Belt on Jenn Air CLothes dryer
1. Disconnect power
2.Use Putty knife and push in to release two spring catches between top and front panel about 3 inches from either side. Top then lifts up. Undo two hex screws on either side of side panels close to top. Front panel then tilts forward. Un-clip door switch and wiring harness before lifting off front panel. If belt is broken, drum should lift off by slowly raising front of drum to disengage wheels at rear of drum.
3. clean accumulated lint from inside fan housing and duct work on front panel as well as from total inside of dryer base before placing new belt around drum, smooth side up before carefully replacing drum in place to engage two wheels at rear of drum.
4. reaching left hand under drum, raise spring loaded idler arm and place ribbed side of belt around pulley on end of motor with right hand before releasing idler arm to provide tension on belt.
5. Place front panel on bottom clips and reengage door switch wiring harness before reattaching hex screws at top of side panels.
6. drop top pannel of unit in place to reengage spring clips before reconnecting power
Dec 24, 2007 | Dryers
Belt replacement
I Can help ..... Remove 2 phillips screws under lint filter pull top of dryer forward and then raise like hood of a car Remove 2 5/16 Hex screws holding front on dryer Disconnect door Switch let front hinge down a tiny bit and up and off Belt is routed with idler hinged into base of the dryer 2 slots
Oct 05, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
paul
paul
