Question about Soltek SL-86SPE2 Motherboard
Pc wont stay on
At first it would start and randomly die (not shut down of restart die).
i mest around in the bios screen now it stays on but its just a black screen wont even boot. when i started up sometimes i would have to push the power buttin 10-15 times untill it booted.
  • tho-masking Apr 02, 2008
    the motherboard seems ok power supply is set to 115 but i cant get into the bios screen to change anything in there. the ram is ok its new this problem was happening before i upgraded. i tried the other pci-e slot and removed my secondary HD theres nothing left in there accept the video card (also new) 2 Gigs of ram mother board and processor.
    Genius:
  • 1,913 Answers
Check your power supply,earhing problem .proper voltafe .
clean your ram,processor and its position.
check that your bord dont touch the cabinet.
other wise i think your bords register or diode transistor are corrupt.
repair your motherbord chipset if above try are not succes
Posted on Apr 01, 2008
HTC stuck on HTC screen...wont start
I would try flashing the kernel separately via fastboot and seeing if that helps
Sep 27, 2012 | HTC 7 Surround Cell Phone
Pc won't start
Think your power supply died. Check that out first since they are relatively inexpensive. Or throw in a known working PS to see if that does the trick. Write back with results for further info.
Sep 17, 2017 | Packard Bell iMedia Computers & Internet
Pc keeps randomly powering off & then back on. Won't stop until I unplug it.Holding down power button won't shut it off. On occasion it will stay on - is able to boot & be used normally while it...
Power supplies usually are culprits in random shut downs, but random start ups is a bit more complicated. You say that when you hold the power button, the computer won't power down. Perhaps you have a faulty switch? Make sure your PW switch cable is securely attached to the motherboard. But I'm leaning more toward a faulty switch or a short in the wires. Seems like a good place to start.
Sep 05, 2009 | E-Machines eMachines Desktop PC
My laptop, emachine m5312 shuts down by itself despite the power settings to stay on, any ideas?
it may be set to hibernate in the bios. if it's randomly shutting down while you are working then you probably have an overheat issue.
Aug 14, 2009 | E-Machines M5312 Notebook
V2000 (2710US) shutting down randomly
try to use other hard disk. if it works on your machine then your OS is corrupted. You might need to reformat your hard disk.
Before reformatting your hard drive safe all the files first because everything will be deleted.
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2710us shuts down randomly with a loud click
Loud click sounds like either a short or overload, causing ground default. recheck inside for any loose connections anything grounding out the motherboard.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
Ibm turns on than shuts down
Hi, May be the harddisk is not recognizing. Restart your laptop and go for BIOS and check whether the harddisk is recognized.
Mar 09, 2009 | IBM ThinkPad R40 2681
Randomly dies/randomly wont start,good battery
I had the same problem, there was a short in the shifter wire.
Dec 17, 2008 | 2000 Ford Excursion
Disable video card
go in bios disable onbord use agp or pci exp setting plug in old way to change those in bios 1st then shut down plug into other
Jan 21, 2008 | E-Machines T6528 PC Desktop
Soltek SL-86SPE2 Motherboard Logo
71 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
Steven Wander
Steven Wander
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
