Question about Videoseven Slim Line L15CM (White) 15" LCD Monitor
Unknown cable voltage for a computer monitor
Hello, I really need some help.
I have recently been given a monitor without a power cable that appears to need an independent power supply.
Though it is branded as being "EXtreme, it is hard to say what make of monitor it is, as a reasonable attempt at searching on line has not yielded anything conclusive.
There is some information on the back of the monitor. Here it is.
L15C
100 - 240VAC 50/60Hz 1.5A
15" TFT LCD MONITOR
S/N:
W149000087
Model ST - 15V
The socket on the back of the monitor is labled DC IN.
What I would like to know, is what type of power cable/transformer do I need.
It may be that I am just being a bit slow but if you could think of anything that would be of help I might stand some chance of getting this thing going. As you may have guessed, I am not what you would call an expert so please be patient with any explaining.
  • 23 Answers
Although this may sound like passing the buck, but search for a specialty LCD repair company. Hundreds of these companies exist.
Posted on Apr 01, 2008
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
Hello: Just recently, the 2159m HP monitor goes to sleep in the middle of an activity. This happened on two desktops and different settings. Repalced the video card, adjusted settings, replsced DVI...
Check the cord and connections for the monitor; this has one wire that must have voltage on it or the monitor goes to sleep, and a broken wire or loose connection will fool it into thinking you are powering down. If this doesn't work try going into power options and setting monitor to never power down.
Jan 22, 2011 | HP 2159M Monitor
Hello, I have 7 no. of Philips 105G7 CRT monitors purchased in 2006. 4 of them are working fine but three of them started failing one by one since a year. First was in July last year and the recent one was...
The cracking problem is probably high voltage arcing inside the monitor due to insulation breakdown or components breaking down or dust and moisture causing arcing. I suggest you dispose of these monitors, they could pose a fire risk. Instead of trying to repair them. Do not try to repair the monitors yourself, there are dangerous high voltages inside these crt monitors.
I suggest you put your money towards a LCD monitor, these are fairly cheap and very energy efficient.
Aug 29, 2010 | Philips Computers & Internet
Light blinking problem in LG 775N ( White ) 17'' CRT monitor
any shortage in secondry side of monitor ..
plz check shoting.
Feb 25, 2009 | Computers & Internet
Hp Pavillion F1703 17 LCD monitor
Yes, the connector next to the speaker connector is for the power adapter. It's different from the speaker plug so you can't put it in the wrong place. Hopefully you got the right power adapter with the monitor.
Here's the page at HP's site where you can download the User's Guide for this monitor. Hope this helps.
Jan 29, 2009 | HP Pavilion F1703 17" LCD Monitor
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
No disc
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 06, 2008 | NetGear WGT624 Wireless Router
What voltage power cable/transformer do i need for an "EXtreme" monitor
I don't know why it specifically say 100 - 240 VAC (That's AC Input), then label the jack as DC IN. So I'd guess it will run on either. Is there a jack or connector for the AC in as well? Most DC inputs are indeed around 12 Volts, this is so they can be operated on vehicle voltage.
Hope that helps a little...
Geno
Apr 02, 2008 | Videoseven Slim Line L15CM (White) 15" LCD...
1501 power supply
The screen comes standard with a LiteOn power supply, 12v 3.3amp
Dec 21, 2007 | HP Compaq 1501 15" LCD Monitor
Videoseven Slim Line L15CM (White) 15" LCD Monitor Logo
60 people viewed this question
Top Videoseven Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Stephan Reichert
Stephan Reichert
William Miller
William Miller
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
